Old 01-08-07, 08:52 PM   #1
rob13
Default Cutting out problem
I appear to have a little problem with the bike cutting out on me. This tends to happen when revving it at standstill (Revs drop and it dies) however it has happened the odd time when braking hard and pulling the clutch in. From what I recall on the last service, i noticed one of the plugs was quite sooty while the other was ok. Can anyone shed any light/tell me what the plug conditions are indicating?
Old 02-08-07, 02:45 PM   #2
barmy.biker
Default Re: Cutting out problem
how high u revving it?
had that problem b4 if i rev the bike repeatedly over 5k in quick succession
thought it was a problem but looked in the manual and found a section that states there is some kinda sensor that will cut the engine out if u rev it like i said above while the bike is stationary to prevent engine damage
Old 03-08-07, 10:16 AM   #3
rob13
hmm now i didnt think i was revving it that high to be honest - just blipping the throttle.
Old 03-08-07, 10:42 AM   #4
Gazza77
Gazza77's Avatar
Idle need adjusting perhaps
Formerly Blue K5 with added bits
Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust
Now Benelli Tornado
Gazza77 is offline   Reply With Quote
Old 03-08-07, 12:05 PM   #5
John 675
Exclamation Re: Cutting out problem
Same thing happend to me, i uped the idle acouple of hundred, hasnt happend since. try it as a starting point, whats it idling at?
Old 04-08-07, 02:05 AM   #6
rob13
Ill check in the morning - just in from work. Whats the tolerances?
Old 07-08-07, 08:26 AM   #7
rob13
Doh, it was the idle i thought it was meant to be idling around 1k which it was, but apparently according the book its 1200-1400 so just knocked it up. Panic over!
Still got a bit of a sooty plug in the back cylinder anyone advise me on that?
Engine cutting off problem mikeyd SV Talk, Tuning & Tweaking 15 26-06-10 11:32 AM
New problem with bike . . . cutting out MacDaddySV SV Talk, Tuning & Tweaking 15 04-03-09 11:25 PM
99' Bike cutting out - odd charging problem. philbert SV Talk, Tuning & Tweaking 6 03-10-08 06:09 PM
cutting out problem. rich dawson SV Talk, Tuning & Tweaking 6 28-09-06 05:27 AM
GSXR Cutting out after a period of high rev's problem mysteryjimbo Bikes - Talk & Issues 7 22-07-05 03:46 PM
