Now that the bikes back on the road and sorted, it seems to have developed a new problem . . .randomly, but not often.
When about to pull away, as I begin to give it some throttle it cuts out, this happens instantly, but starts fine straight after. The way in which it cuts out (really quickly) makes me think its something electrical, such as a dodgy cut off switch, or side stand switch. Obviously it could probably be because of a number of other things, but dont think its anything to do with the previous carb problem. If anything its just annoying as it looks like Im stalling the bike! ![]() Anybody else had a similar problem? cheers |
how old is it?
See his sig
![]() I'd say sidestand switch and start lobbing the wires off the relay and bypassing it entirely. Idiot switches are no use to anyone, you will only forget about the sidestand once...
Apart from the electrical problems is your tickover set a bit low?
Yes. Possibly your problem there. 1300rpm +/- 100
The way it cuts out is in the same way as the sidestand cut off . . ..as in it happens in an instant, and is not like the engine is choking or something.
Try up the idle see if it works. If not then start chopping wires.
#9 |
#10 |
Engine cutting off problem | mikeyd | SV Talk, Tuning & Tweaking | 15 | 26-06-10 11:32 AM |
99' Bike cutting out - odd charging problem. | philbert | SV Talk, Tuning & Tweaking | 6 | 03-10-08 06:09 PM |
Cutting out problem | rob13 | SV Talk, Tuning & Tweaking | 6 | 07-08-07 08:26 AM |
cutting out problem. | rich dawson | SV Talk, Tuning & Tweaking | 6 | 28-09-06 05:27 AM |
GSXR Cutting out after a period of high rev's problem | mysteryjimbo | Bikes - Talk & Issues | 7 | 22-07-05 03:46 PM |
