Old 05-08-07, 10:05 AM   #1
steveg
steveg's Avatar
Question scotoiler Lube Tube
Hi
I have a std scotoiler fitted which I am really pleased with , however would like to increase the range , the touring kit I believe can't be fitted under the shoval mudguard on a k5, therefore looking at fitting a lube tube to extend capacity , they cost 20 quid & extend range to about 2k miles which would be good .
Any one fitted one to a pointy , do they fit ok under rear seat / recommended?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 05-08-07, 04:23 PM   #2
petevtwin650
Default Re: scotoiler Lube Tube
If you do decide to get a lube tube Steve, I've got one that I only fitted for a few weeks. Worth a Tenner?
Old 05-08-07, 09:59 PM   #3
steveg
steveg's Avatar
A quick question why are you selling it after only a couple of weeks ?
Don't know anyone who has used a lube tube thats why I ask
Cheers Steve
AKA Papa Smurf
Old 05-08-07, 10:04 PM   #4
Lissa
Just Ballast
Lissa's Avatar
We just couldn't get on with the scottoiler, Steve, couldn't get it to flow the way we wanted. We've just gone back to lubing the chain after every run.
Old 05-08-07, 10:14 PM   #5
steveg
steveg's Avatar
fair enough , can you bring lubetube & its bits to the Wales run & I'll buy it from you , a tenner seems fair
Cheers Steve
AKA Papa Smurf
Old 05-08-07, 10:25 PM   #6
Lissa
Just Ballast
Lissa's Avatar
No worries, Steve. We'll bring it then.
Old 06-08-07, 09:13 AM   #7
Ceri JC
You're right in thinking you can't fit the touring kit, it broke both mine and The Mass' number plate hangers.
The lube tube is good, but I find it more prone to getting air bubbles in between it and the main scottoiler than the touring kit did. It still seems to feed enough oil through though and it's worth having if you do the miles. HTH
Scotoiler? skapegoat SV Talk, Tuning & Tweaking 5 05-02-09 12:54 PM
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Scotoiler Slapstick Stuff Wanted 8 21-02-07 09:59 AM
Lube Tube?? New Leaf Bikes - Talk & Issues 13 11-12-06 06:51 PM
scotoiler russg SV Talk, Tuning & Tweaking 12 11-03-06 11:37 PM
