Old 10-08-07, 05:42 AM   #1
Lakes_Puma
Default Datatool S4 RED, has anyone got one fitted?
If yes, does it work correctly!?
I hade one fitted to my bike when I bought it and from day one the nudge sensor part of the alarm never worked, so I contacted the dealer and they ordered a new alarm that was fitted yesterday and it's exactly the same.
If I move the bike the movement sensor will trigger the alarm (I can tell which sensor due to the number of beeps when I disarm it) but no ammount of kicking or hitting will tigger the nudge sensor.
I am getting bit p!ssed of to say the least and don't want to be without the bike for another day while the dealer tries to get it working.
So has anyone get this alarm fitted and working as the blurb says it should?
Old 10-08-07, 08:10 AM   #2
gettin2dizzy
Default Re: Datatool S4 RED, has anyone got one fitted?
are you arming it or letting the 45 seconds pass so it arms itself?
Old 10-08-07, 08:25 AM   #3
Lakes_Puma
I am using the remote to do a full arm within 45 sec of turning the ignition off.
Old 10-08-07, 09:11 AM   #4
DoubleD
I don't have the same alarm but I know that when I arm it you have to wait around 30 seconds for it to be fully active. The alarm LED flashes fast during these 30 seconds then goes to a steady slow flash when done.
HTH
Old 10-08-07, 09:51 AM   #5
gettin2dizzy
If you let it arm itself (beep .......beep....beep..beep beep beepbeepbeep) - that one then it only activates the immobiliser. I found the nudge sensor only goes off for sharp nudges. If I lightly tap the wheel with my chain it goes off!
Old 10-08-07, 10:11 AM   #6
John 675
Exclamation Re: Datatool S4 RED, has anyone got one fitted?
I have the same allarm mate and it does exactly the same, the sensitivity is turned right down as standard, if you pick your bike up it will go off right?
i arm it as soon as i turn the egnition off, try giving it a shake for a while and you will get a few bleeps then it will go off but those bikes that go crazy when you breath on them have the sensitivity on MAX, dont worry to much about it just get your dealer to change the settings for you,
Datatool problem. chakraist SV Talk, Tuning & Tweaking 20 17-05-09 05:55 AM
Help! Plz.. Datatool keeny90 Bikes - Talk & Issues 18 03-08-08 09:15 PM
datatool system 3 evertheoptimist SV Talk, Tuning & Tweaking 17 02-06-08 10:05 PM
Datatool 3 alarm help ... sprocket SV Talk, Tuning & Tweaking 20 29-11-05 05:01 PM
Datatool System 3 TSM SV Talk, Tuning & Tweaking 1 16-07-05 11:48 AM
