Old 24-08-07, 01:14 PM   #1
SVStu
Default Dragging Clutch help
I have a 99 curvy and the clutch is dragging making it difficult to find neutral etc.
Its not usually a problem as I only use the bike for pleasure and have adapted my riding style to find neutral when aproaching lights etc rather than when at rest and the clutch is under load.
I'm just about to start using the bike to commute and it could become a problem with city riding.
I've done all the usuall adjustments at both end of the clutch cable but can not adjust the drag out.
What could it be??? Stretched clutch cable/new worm screw/new clutch plates/steels??
Any ideas ppl?
Old 24-08-07, 01:16 PM   #2
jambo
jambo's Avatar
Default Re: Dragging Clutch help
Searches on "Clutch Adjustment" will bring up such threads as this one. Sid Squid's comments should be a 1st point od call:
http://forums.sv650.org/showpost.php...54&postcount=7
Old 24-08-07, 01:31 PM   #3
Biker Biggles
Biker Biggles's Avatar
Also check chain tension and engine oil level.When was the oil last changed,as that also can affect clutch function.
Dragging Jeans??? slloyd Suits 16 11-04-09 05:09 PM
Rear brake dragging. daveb SV Talk, Tuning & Tweaking 5 23-11-08 08:32 AM
lost neutral & dragging clutch weazelz SV Talk, Tuning & Tweaking 6 24-05-07 11:49 AM
Knee dragging! Jamesv650 Bikes - Talk & Issues 8 22-08-05 04:19 PM
Knee dragging! nicknoxx SV Talk, Tuning & Tweaking 3 05-01-70 11:51 AM
