Old 28-08-07, 09:52 PM   #1
chipnix
Default Purchaced a cheap TL1000s
decided to try one and see how i get on..found this one....
Has a Maxtor rear suspension unit, front damper, 6 pot breaks (thing thats the technical name) datatool system 3 alarm and a cool number plate
Gona do it up bit by bit till its a minter again.
Old 28-08-07, 10:12 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Purchaced a cheap TL1000s
Stock steering damper, stock rear SOAS (normal, they do have a short lifespan though).
Good though, need to change thoes cans, too quiet like that.
Old 28-08-07, 11:17 PM   #3
fat_brstd
great bike, very similar to mine, hope you dont mind but how much did you pay for it and what year is it? Those brakes are off a hayabusa and they will stop you in no time at all same as i have and very nice. Really really change those end cans (if you get baffled ones i would happily take the stock ones off your hands if you fancy recouping a couple of quid, mine has micron end cans with no baffles and puts on 122db which is to much for a track day so im trying to find a way to make it quieter).
Also dont take the stearing dampner off, i did for a grand total of 20 mins, it is there for a reason.
Old 29-08-07, 07:55 AM   #4
TSM
The Sick Man
TSM's Avatar
Its not all that bad, just have to be very careful opening that throttle over bumpy roads. But overall keep it on.
Old 29-08-07, 08:18 AM   #5
SoulKiss
SoulKiss's Avatar
SATA or IDE???
Old 29-08-07, 08:22 AM   #6
DoodleBug
Looks good, those 6 pots are better than the standards but may seize if used in cruddy weather alot, not a big problem just watch out for it. I have also fitted a radial master to mine from a 999, bought a minter off fleabay, the brakes went from good to oooomyyyyyyyygawd good
Have fun.
Oh and make sure your clutch cable is regularly lubed, the clutch gets v.v heavy if it isnt.
lastly dont be alarmed if there is a slight oil leak/mist coming from the clutch cover, it is a known and common fault which is easily remedied.
Old 30-08-07, 04:44 PM   #7
Nice! Ow much mister?
Tl1000s/r Gra Bikes - Talk & Issues 32 20-07-08 06:25 PM
TL1000S Marshall Bikes - Talk & Issues 42 04-07-07 03:59 PM
TL1000S or VTR1000 jayjay Bikes - Talk & Issues 21 14-02-07 05:30 PM
tl1000s kwak zzr Bikes - Talk & Issues 6 14-10-06 03:31 PM
TL1000S Clip-ons mr&mrs_sv Stuff Wanted 4 07-03-06 09:35 PM
