Old 29-08-07, 03:10 PM   #1
Tiger 55
Default Can I hoover an air filter?
Mr Haynes says to blow the dirt out from the engine side but I don't have an air blowing device so can I suck it from the other side using a hoover?
It's not the SV filter, it's the wife's CBR125 filter which looks like this...
Old 29-08-07, 03:13 PM   #2
jonboy99
Default Re: Can I hoover an air filter?
All the filters i've had say you should use tap water from the clean side, and compressed air will damage it. (K&N and green cotton car filters).
Old 29-08-07, 03:18 PM   #3
hovis
i did
Old 29-08-07, 03:20 PM   #4
jambo
jambo's Avatar
Stock filters for most bikes are not "washable" as I understand it. It'd be a shame to turn the filter into a piece of artwork....
Old 29-08-07, 03:22 PM   #5
jonboy99
Whoops, didn't realise he meant a stock one.. Don't get it wet then!
Old 29-08-07, 03:37 PM   #6
Tiger 55
Should've mentioned it's the stock Honda item. The K&N one in the picture is just that, a picture!
Wouldn't have washed it though, although it's not like I can say 'I'm not that stupid' because I am exactly that stupid...
Old 29-08-07, 04:00 PM   #7
the white rabbit
I hovered mine and can report.....
........no discernable change
It did look cleaner tho, which must be good....I suppose.
Old 29-08-07, 04:15 PM   #8
embee
embee's Avatar
Yes, vacuum cleaner is just the ticket.
Air filter elements last a lot longer than the normal recommended change interval under typical UK conditions. What does for them is fine dust from unsurfaced roads, or even worse heavy industrial smoke pollution like the old "smog".
An air filter will be fine for 20-30k miles in the UK.
Old 29-08-07, 06:40 PM   #9
toonyank
You can use a hoover but an compressed air will get into the fibre and get the bits you can't see.
Take it to a garage and use the compressor for tyres. If it's the manual type and not the auto type it will do fine.
Old 30-08-07, 06:56 AM   #10
Tiger 55
Manual? Auto? To the garage!
dyson hoover + henrey carpet washer for sale green kurtis.randle Idle Banter 7 26-04-09 09:10 PM
Hoover washer/dryer noise.Need some advise please. monkey Idle Banter 24 14-05-08 08:47 PM
Hoover Humper Dicky Ticker The Essex Lounge 7 10-03-08 12:04 PM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
