Old 19-09-07, 05:17 PM   #1
ClemsonSV
Default Came to a stop at a light and the bike would not...
SHIFT!!! I got down into 3, but that was it. This has happened one other time as well. What in the world is going on in my transmission???
Old 19-09-07, 05:21 PM   #2
ASM-Forever
Default Re: Came to a stop at a light and the bike would not...
I would suggest taking apart the gear change linkage and cleaning/greasing.
Worked for me on my R6 after my mate had been messing with it. My symptoms were the same.
Old 19-09-07, 06:03 PM   #3
CB1ROCKET
actually all bikes i have own, needs you to shift the gears when blipping the throttle and letting the clutch bite a bit then kick it down through the gears and repeat if necessary. The best thing is to antipcate gear change into neutral before you stop. ie while still rolling up to the lights, change the gears while still in motion.
Old 19-09-07, 07:17 PM   #4
ClemsonSV
Thanks...I forgot to mention it was a bit of an emergency stop but I was down shifting while still moving...that was of course until I got stopped.
Old 19-09-07, 07:33 PM   #5
CB1ROCKET
Yeah it can get stuck quite hard when doing hard braking or in an emergency, just let the clutch bite a little, pull it back in again and try shift it down. on normal riding i dont generally have to do this, just as long as you make each gear shift nice, smooth and fully up/down on the shifter.
Old 20-09-07, 11:38 AM   #6
johnnyrod
johnnyrod's Avatar
This type of gearbox basically doesn't work unless the bike is moving, you'd need to roll it back and forth a few inches while pressing the lever to make it happen. They're not like car gearboxes.
Old 20-09-07, 05:45 PM   #7
thedonal
Check the gear lever/footrest are tight and secure on the hanger too- if it's wobbly it'll cause you murder changing gears. It did for me!
Old 20-09-07, 06:40 PM   #8
TSM
The Sick Man
TSM's Avatar
emergency stop, just brake, forget about the gears you are wasting your time, deal with that later, ofcourse if the situation requires a hard stop then go you need to work it all out.
Ive found under hard braking, the gearbox does not like changing gear unless you blip, which you dont want to be doing if you need to emergency brake.
Old 20-09-07, 09:38 PM   #9
toonyank
Just like he said and nothing more
Old 21-09-07, 02:33 AM   #10
ClemsonSV
Thanks for the help. Next time I have to stop short I'll keep it in mind. I'm not about to go try just for fun....
Fuel light won't stop flashing. Tim in Belgium SV Talk, Tuning & Tweaking 10 05-09-07 11:06 PM
clear tail light / stop light Lens for sale SVTONYB For Sale - SV's and SV related items 7 20-05-07 04:55 PM
How do you stop dogs peeing on your bike? Davies Idle Banter 23 19-03-07 07:12 PM
Tail stop light doesn't work when using rear brake FlyinRegie SV Talk, Tuning & Tweaking 5 15-12-06 05:07 PM
how to stop a robber on a bike - Quiff Wichard Idle Banter 6 05-11-06 08:20 PM
