Old 09-11-07, 01:26 PM   #1
Captain Nemo
Default My new build desktop dont work!!!!! @*$%%% !!!!!
grrrrr,
just had a new desktop build my a local reputable shop, got it home to set up, connect everything up and turn it on, lovely picture as xp loads,
then nothing happens, mouse and keyboard dont respond.
ive got a £600 picture frame,
when i restart the machine and go into the bios it shows that ive connected keyboard and mouse ( all usb) ive even tried connecting 2 key board 2 mice, and it all shows in the bios as being connected,
only when windows comes up , nada, the little bubbles come up saying human interface device connected and that but they dont work , no lights on the keyboard, funny enough they com eon on the mouse.
its going back in tomoz and theyll sort it,
but in the interim any idea why its doing this now??
theyve obviosly had it running in the shop cos theyve put software on it for me........
cant buy otw these days can you........
nowts ever simple.
Old 09-11-07, 01:42 PM   #2
Sosha
Default Re: My new build desktop dont work!!!!! @*$%%% !!!!!
No... sorry but if it makes you feel better my boss and I once built the Antichrist. An creation so disasterous we had to sit out the next round til our collective confidence recovered...
Old 09-11-07, 01:45 PM   #3
rictus01
rictus01's Avatar
I'd suspect they built it with a standard ps2 keyboard & mouse (generally a green and purple round socket on the back) and not the USB items, perhaps your make of keyboard & mouse isn't supported as standard and needs specific drivers for XP (although these days that's a little unusual), these should have come wqith the devices, if you didn't get the disc then have a look at the manufactorers website for info or maybe downloads.
Cheers Mark.
Old 09-11-07, 02:10 PM   #4
600+
Old 09-11-07, 02:12 PM   #5
Viney
What a laugh huh?
Go back and use it as a £600 negotiation tool.
Old 09-11-07, 07:03 PM   #6
TEC
TEC's Avatar
Originally Posted by Captain Nemo View Post
just had a new desktop build my a local reputable shop..... ive connected keyboard and mouse ( all usb)
You will look a bit silly when you take it back and it all works on standard PS/2 kit. But saying that if it was built using USB (I very much doubt that) then was it done on USB 1 or 2, are your KyBd & Rat USB 1 or 2 Rat shouldn't matter so much but the KyBd will as it needs power, not all USB ports provide power. If the PCs MB has multiple ports (some front, some back), have you tried using different ports. Have you tried a normal KyBd but a USB mouse and other way round
I am behind you
http://wildwesternadventures.com/
TEC is offline   Reply With Quote
Old 12-11-07, 11:22 AM   #7
Captain Nemo
took it back.........twice.......
it was built with a ps mouse kb, but i told them i had usb stuff when they built it.
took it back first time and he set it up properly with the usb stuff,
got it home and it still wouldnt recognise the usb stuff without the ps2 ones in ,
so tole them that i didnt want a £600 picture frame, and that if it wasnt fixed today im returning it unfit for purpose and cancelling the cheque.
so they flattened the OS and reinstalled it and now it appears to be ok, they suggesteed that possibly the clone they built it from might be corrupt.
seems ok, was really fast, , right up till i put the AV on...........
i didnt realise not all usbs can provide power? whys this?,
is this poss the reason that my wireless mouse dongle is only recognised in the front ports and not the rear ones, or is that another bug??
Old 12-11-07, 11:38 AM   #8
Baph
1) One of the pins on the USB connector is 5v +ve, another is ground. That's in the USB spec (RFC), so ALL USB 1.1/2.0 ports should give power. If they don't, something is wrong.
2) If the drivers were installed whilst the dongle was in the front ports, there's a chance that they will only work on the specific USB ID assigned at the time (there'll probably be an entry to change somewhere in the registry). The easiest solution is to plug it in the back and re-install the drivers. You can navigate around Windows with only the keyboard whilst installing. Look for underlined letters in a word, hold the ALT key and press the letter, it's the same as clicking on the button with the writing on it.
There are more keyboard shortcuts, but the TAB button will help you navigate too. Failing that, phone the shop, and tell them that it doesn't work as you want it to, so they can either come to your house & fix it (as it costs you to keep taking it back to them), or revert to your original plan of cancelling the cheque.
PS. The "clone it was built from is corrupt" is the technical way of saying "we don't know what happened, but it's fixed now."
Old 12-11-07, 11:43 AM   #9
Pedro68
Perhaps PC's should have a dedicated "security processor" (like they do a GPU - graphics processing unit), that will handle all aspects of security (AV/Firewall/Spyware) so that it doesn't interfere with the actual tasks you bought the damned thing for in the first place
Too low-spec'd power supply IMHO? I've seen a few so-called "system builders" overlook this aspect and it (along with the case) is often the first place they look to "cut the price" of the PC.
Nope ... sounds like a bug to me ... shouldn't be any difference between back/front/side USB as far as I'm concerned.
EDIT: sorry, just thought ... how many USB devices you got plugged in and what is the power rating (wattage) of the PSU?
HTH,
Pete
Old 12-11-07, 12:15 PM   #10
tigersaw
tigersaw's Avatar
erm you do have a genuine copy of Vista installed dont you? Not that that relates to your problem, but it will come back to haunt you if not
Help me tidy up my desktop please Stu Idle Banter 8 21-09-08 08:21 AM
Honest guys this does work, dont dismiss it!!! Jimmy2Feet Idle Banter 1 08-12-06 11:31 AM
Desktop versus laptop Razor Idle Banter 17 20-11-06 12:11 PM
my bike dont work. can any one help???? unlucky rider SV Talk, Tuning & Tweaking 16 02-08-06 03:39 PM
Hey Greg, dont lock posts just because you dont agree! AlanSv SV Talk, Tuning & Tweaking 110 20-11-04 05:21 PM
