-   -   Knackered ignition key barrel ? (http://forums.sv650.org/showthread.php?t=102794)
kcowgergmm 15-01-08 06:12 AM
Re: Knackered ignition key barrel ?
i use a spray graphite ocasionally
mitchbligh 15-01-08 04:50 PM
Mines the same. I might try WD40 to clean then drop a bit of oil on my key to lubricate. Good idea?
Alpinestarhero 15-01-08 04:59 PM
I'd go with the penetration spray, then put the key in and turn the key a few times (from lock to "off" position), let it all penetrate, then put a bit of oil down there. Occasionaly my key barrell gets a bit stiff, but when I notice this i just spray down some penetrive spray (AC90 for me) and it smoothens things back up again
Matt
Dangerous Dave 15-01-08 05:43 PM
As everyone else says, oil/wd40 will do the job!
andyharding 15-01-08 05:48 PM
Originally Posted by POGS69 (Post 1386443)
I had the same issue.....I had a new key made and it solved the problem:p
Where can you get new keys cut. Are they just a standard key than any key cutting place can do.
My Key wont turn unless i push it upwards as i turn it
Dangerous Dave 15-01-08 05:52 PM
Had the same problem a few years back with my curvy, I got a set of blank keys from my dealer and took them to a local key cutter. Not sure how much a blank key can cost, got both mine for next to nothing as it was a cancelled order.
