Old 14-01-08, 09:01 PM   #1
stewie
Default Knackered ignition key barrel ?
Im finding it increasingly more difficult to actually turn the key in the ignition when starting the bike and am getting a bit concerned that Im goin to break the key miles from home, is it a common thing ? my curveys done 33,000 miles and is great in every other aspect, thing is, if it needs replacing is it an easy job or best left to someone that actually knows what they are doing ?
stew
Old 14-01-08, 09:07 PM   #2
pmapp
pmapp's Avatar
Default Re: Knackered ignition key barrel ?
Silly, question - but have you oiled it?
Old 14-01-08, 09:14 PM   #3
Biker_Billy
+1, thought mine was on its last legs, but a lot of penetrating spray, wd40, and its smooth as silk now....
Old 14-01-08, 09:25 PM   #4
pmapp
pmapp's Avatar
Tis exactly why I asked - mine was really bad until I dropped a wee bit of oil in it.
Old 14-01-08, 09:38 PM   #5
Richie
fantabulas
Richie's Avatar
Thats what happen'd to mine and a spot of oil did wunders....
My Flickr photos
Old 14-01-08, 09:38 PM   #6
Mine's well oiled but you still have to tilt the key forward slightly to turn the key.
Old 14-01-08, 10:57 PM   #7
POGS69
I had the same issue.....I had a new key made and it solved the problem
Old 14-01-08, 11:33 PM   #8
stewie
I have but maybe need to get some wd40 into it see if that makes much difference, cheers guys
Old 14-01-08, 11:34 PM   #9
injury_ian
+1 on oil I used 3-in-1 tho.
Old 15-01-08, 12:38 AM   #10
WD40's more solvent than oil... If your lock has any original lubricant left WD40 might be counterproductive. OTOH if it has muck in it causing problems WD40 might help. I use engine oil though, mine was almost completely useless for a bit but now it's fine.
Ignition barrel borked after off? MiniMatt SV Talk, Tuning & Tweaking 1 26-10-07 11:37 AM
Ignition Barrel Help! krhall Bikes - Talk & Issues 7 19-02-07 11:13 PM
Ignition Barrel BILLY SV Talk, Tuning & Tweaking 12 24-08-06 09:02 PM
Faulty Ignition Barrel ??? leegriffiths128 Bikes - Talk & Issues 25 22-04-06 03:08 PM
Ignition barrel for a K2 Mervin Stuff Wanted 0 03-01-06 04:29 PM
