Old 23-08-06, 05:14 PM   #1
BILLY
Default Ignition Barrel
What is the best way to remove the ignition barrel from the top yoke with a special tool?
Any help would be much appreciated.
BILLY
Old 23-08-06, 06:33 PM   #2
It's a torq bolt, you can buy them in sets from Maplin or Machine Mart for around a fiver, or they tend to come in most screwdriver kits. I can't remeber if they've got the stud in the middle or not, make sure you get the right sort!
Also, mine were red threadlocked in- so all in all, they were an utter ****** to shift. Bloody useless things, there might be some point if the bits weren't so easy to find. So I chucked 'em in the bin and fitted a proper bolt
Old 23-08-06, 07:22 PM   #3
haggis
They do have the security stud. I centre-punched and drilled out the wee stud. They're also lock-tited in, so a screwdriver might not give you the required leverage. just a thought.
Old 23-08-06, 07:25 PM   #4
haggis
Originally Posted by northwind
Also, mine were red threadlocked in.....
Oops didn't read the whole reply. Sorry, didn't mean to repeat.
Old 23-08-06, 11:00 PM   #5
It's not like it was a big reply
I think the Maplin green set has the right bits to deal with the centre stud.
Old 24-08-06, 12:54 AM   #6
BILLY
Thanks guys I'll go do some shopping
Old 24-08-06, 03:18 PM   #7
Ter
Bought a 'security' torx set from Maplin, costs about £6/7
Come with predrilled bits so there no need to worry about the stud in the ignition lock bolts,
Old 24-08-06, 06:35 PM   #8
Bluepete
Bluepete's Avatar
Got a set by laser tools from the local car repair shop for £4.99 including a 90 degree "spanner" allowing very easy removal of these exact bolts!
Old 24-08-06, 08:38 PM   #9
BILLY
Thanks guys Iv'e got a set now from Machine Mart so the jobs a good un
Old 24-08-06, 08:45 PM   #10
Razor
Mine were so corroded I had to use an impact driver, but I like hitting things with a hammer.
Knackered ignition key barrel ? stewie SV Talk, Tuning & Tweaking 15 15-01-08 05:52 PM
Ignition barrel borked after off? MiniMatt SV Talk, Tuning & Tweaking 1 26-10-07 11:37 AM
Ignition Barrel Help! krhall Bikes - Talk & Issues 7 19-02-07 11:13 PM
Faulty Ignition Barrel ??? leegriffiths128 Bikes - Talk & Issues 25 22-04-06 03:08 PM
Ignition barrel for a K2 Mervin Stuff Wanted 0 03-01-06 04:29 PM
