Re: MOT failure
i have no idea either, will try and get the flippin thing bled so it actually works (effeciency was down to 18%)
Have found i can also get a new m/c for £35 as well |
Re: MOT failure
Re: MOT failure
Re: MOT failure
it means your brake pedal is bottoming out, a bit like if the front brake lever would pull back to the handlebar.
Re: MOT failure
Ah right, see now why couldn't they just put that on the failure sheet? :rolleyes: |
Re: MOT failure
you dont get a choice of what to put down, you just pick the reason for failure from a list of fancy worded versions!
Re: MOT failure
Just do what I do when I can't be arsed to bleed the brakes. Give it lots of pumps whilst you're not moving!
Re: MOT failure
Not sure the Raptor would like you doing that!
Re: MOT failure
Re: MOT failure
It may turn round and bite you ;-)
