Old 24-04-09, 09:49 AM   #1
dirtydog
Knob faced knobster
dirtydog's Avatar
Default MOT failure
Right the Raptor went for it's MOT yesterday and failed on it's rear brake again
so apart from it being the worst rear brake I've ever used on a bike (not very effective and a rubbish design making it a pig to bleed properly) it failed on this
"Brake pedal has inadequate reserve travel"
What the hell is that meant to mean????
2001 SV650 in shimmerin green, Not broken anymore
Old 24-04-09, 09:52 AM   #2
Owenski
Default Re: MOT failure
I think that means, bring it back in a weeks time cos this credit crunch is killing us and we have nothing to do.
Old 24-04-09, 09:56 AM   #3
jimmy__riddle
i would guess it means that the brake pedal is moving to its maximum travel to work. i.e. moving too far.
Old 24-04-09, 11:09 AM   #4
Did you manage to have a go at the trick Matt sent you for bleeding it?
Raptors are notoriously sh!te on the back brake....good system just Cagiva fooked it up when they hung it the way they did.
Dunno what to suggest really
Old 24-04-09, 11:36 AM   #5
Dicky Ticker
The stroke/travel of the brake lever must be near its maximum----------is there an adjusting rod or screw to the rear brake cylinder which will shorten the movement on the pedal------------leaving more travel in the pedal to allow for brake pad wear.
Best I can suggest as I have no idea of the rear brake set up on a Raptor
Old 24-04-09, 11:40 AM   #6
ophic
ophic's Avatar
I'd go back to the MOT place and ask them to explain exactly what they mean.
What makes it so hard to bleed?
Silver SV650SK3, Fuel exhaust
Old 24-04-09, 12:07 PM   #7
You have to do it like this, as normal way just do't work!
http://www.apriliaforum.com/forums/s...ad.php?t=15500
You have to bleed it the opposite way or something, rather than air going to nipple, yu have to make it go back up to the cylinder.
The bleed nipples at the top, and theres a whole load of brake line in a wiggle too.
In all the brake calipers etc are ok, Brembo I think, well the front ones are, but Cagiva were a bit thick when they put it on the bike
Aprillia use the same system as the Raptor.
Old 24-04-09, 12:11 PM   #8
jimmy__riddle
ahh, yeah notorious for not working!
Old 24-04-09, 12:18 PM   #9
dirtydog
Knob faced knobster
dirtydog's Avatar
Going to give them a good going over this weekend, was going to do it today but the morning seems to have escaped
There is an adjusting bolt which stops the pedal coming up too far so the brake works earlier if that makes sense?
Indeed they do, infact the Raptor has got a mille m/c on it at the mo cos the original seized up and never worked properly again after that. The caliper itself is fine it's just the rest of the set up. On the plus side I should be able to get a new rear disc for £53 which isn't too bad considering the last one cost me £80
Old 24-04-09, 12:22 PM   #10
Yeah, when Matt firstcame across this problem he pinched the M/C off YC's Cagiva Planet 125. Tiz the same on that too, just not anodised.
Still can't understand what your tester phrase meant....>>>>he shrugged too
MOT failure pinman Bikes - Talk & Issues 46 22-04-09 09:27 PM
MOT Failure melody Idle Banter 33 24-02-09 03:06 PM
Failure Dicky Ticker The Essex Lounge 14 30-10-08 08:52 PM
What a con! – MOT failure Blue_SV650S Idle Banter 30 25-05-07 07:11 PM
Engine failure... Rob_ SV Talk, Tuning & Tweaking 13 01-06-06 10:22 PM
