-   Bikes - Talk & Issues (http://forums.sv650.org/forumdisplay.php?f=129)
-   -   Can injectors be cleaned? (http://forums.sv650.org/showthread.php?t=152083)
Preston 24-05-10 03:05 PM
Re: Can injectors be cleaned?
injectors are easy to clean.. injector cleaner is ok but dont really do alot .. always best to have em out and give em a good clean out with carb cleaner...
its a good idea to get them sonic cleaned ( UV BATH ) and flow tested, as the jets may be damaged, and since they are only there to inject fule in a SET! fine pulse/spray cleaning will not be enuff if they are damaged, it dos not cost much at all.. am lucky to own a UV bath and comprest air tools/machines so i do it all myself.
but if you google injector clean / testing am sure you will find lot of places that will help you out..
widget 24-05-10 04:08 PM
I did find a place but only does top feed.
Am i restircted to just k3 throttle bodies as ive found quite afew on ebay but not sure if other years will fit.
