Old 22-11-08, 02:19 PM   #91
Caddy2000
Default Re: K6 Pointy GSXR Front End Mod
Originally Posted by amnesia View Post
Speedo finally sorted out this weekend.
I fitted a different sensor that was smaller than the GT1 so that I could increase the gap between the sensor and magnets.
Its not been tested to a GPS, but its accurate to my OH's Bandit and the odo shows within 1% of my friends FZ1 on a 45mile jaunt.
Fantabulous....
...it means I can sell all my OEM front end bits now, and reclaim some of the £900+ the job has cost me!!
Just out of curiosity like; what sensor are you using now?
Managed to pick up a pair of mint K7 750 forks, bottom yoke, mudguard and calipers so far, should be interesting........
Old 22-11-08, 06:22 PM   #92
amnesia
I am using a Hamlin 55100 3H 02 A sensor which I bought from Farnell
Old 23-11-08, 12:51 PM   #93
Caddy2000
Minimum purchase on plastic from Farnell is £20 - Bugger!!!!
Looking at Digi-Key
Old 23-11-08, 04:07 PM   #94
just out of interest i used these, worked a treat...
sensor:
http://uk.rs-online.com/web/search/s...0701&x=31&y=18
magnets:
http://www.first4magnets.com/f4645--...ck-20-23-p.asp
to fix the magents i used Steel Grip 2 part from halfords...
get a piece of cling film and cover an area big enough on a worktop or table to fit your disc on then place magnets in the rotor holes, lay your disk 'outside' down on top of the cling film so the magnets are on the worktop/table. push the magnets down with a cotton bud so as they are as flat to the worktop/table as possible. mix the Steel Grip 2 part on a scrapper or something, fill the 'back' of the rotor holes with the Steel Grip 2 part so as it is just proud, leave to dry then file flat or leave how is....
i made a bracket with the pitch of the mudguard bolt fixings then drilled a hole for the sensor.. my sensor ended up right next to the top mudguard fixings it is a gsxr100 k2 front... doesn't matter what the bracket is made from as long as its strong enough.. e.g. cheep plastic or stainless scraper.. i also found that i had to get longer bolts for the mudguard fixing so i could get a nut on the end to fix the bracket to..
i also spliced the original speedo sensor wires to the new sensor...
i have a word document explaining it all in a little more detail if you are interested...
Old 23-11-08, 09:36 PM   #95
Caddy2000
That's a fairly pricey sensor you've used Bibio (well, compared to Amnesia's sensor), still, I am going to look into it though.
I haven't even looked at magnets yet
Old 24-11-08, 08:38 PM   #96
Caddy2000
I've been looking into the Hamlin sensor and really like the look of it.
I found the datasheet on it, and the one that Amnesia has should be used about 18mm away from the magnets (depending upon the magnet of course), you can also get it with different connectors (but I guess that it can't be that difficult to fit your own). I can either get one from Digi-key with a £12 delivery charge, or but £20 worth from Hamlin.
If I bought 4 or 5 of these would there be anyone of interest?
Old 28-12-08, 02:57 PM   #97
Caddy2000
Hey Amnesia,
Got a quick question with regards to the hamlin sensor...
.... Which wire goes where? On my sensor I've got a black, red, and blue.
Paul
Old 31-12-08, 01:03 PM   #98
amnesia
Have a look here...
http://forums.sv650.org/showpost.php...8&postcount=85
This gives the SV - GT1 - Honeywell wiring colours, which helps a bit.
From this the SV wiring is...
Orange / Red trace = Live
Pink = Sensor Output
Black / White trace = Ground
Then wire the sensor the following way...
"Sensor Red" to Orange / Red trace
"Sensor Black" to Black / White trace
"Sensor Blue" to Pink
Now this is based on a POINTY colour scheme, if your SV colours are different then I would ask Yorkie Chris or Northwind. Or, if you have a meter you can determine which your live and ground wires are and connect accordingly.
The sensor flashes its LED when its active, so its easy to see if its working or not before you fix it to the bike, just power it up and wave it around the magnets and the LED comes on when it activates. You can do this using a 9V battery and leave the blue output wire unconnected.
Things to check...
the sensor is polarity sensitive - the magents have to be the right way for them to activate the sensor.
make sure your magent to sensor distance is within the range specified on the data sheet http://www.farnell.com/datasheets/54441.pdf it needs to be a little less than the distance stated in table 1, column 4. That distacne will depend ont eh version you bought.
if its an accuracy issue, then check the magent / sensor distance and whether you need 4 or 8 magnets.
Old 07-01-09, 12:05 PM   #99
Caddy2000
Cheers for that Amnesia,
Wired i up using a chocolate block for the moment, and it seems to work. Will have a better idea when I have the wheel on the bike.
Will post some photos soon.
Old 26-02-09, 01:46 PM   #100
Miles
What is the going price for a complete K4ish GSXR 600/750/1000 front end?
Am I right in thinking from the donor bike the following is needed, for a pointy:
Forks
Calipers
Disks
Wheel
Yolks
Fender
Speedo
Spindle
Also need
Clip ons
Speedo fix
The current SV tyre can be put on the GSXR rim?
Am I missing anything?
What sort of money can be had for the left over SV parts (mint)?
With however many months under your belt, are you happy the cost / work required was worth it Amnesia?
GSXR front end parts for pointy conversion. svdemon Stuff Wanted 37 21-04-08 08:08 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
FAO gsxr front end pointy owners. clip on clearance issues ianofbhills SV Talk, Tuning & Tweaking 10 05-09-06 04:59 PM
