Old 28-04-10, 12:28 PM   #91
Owenski
Default Re: Which GSXR forks etc? (Yet again).
you'll need some sort of steel fabricator I'd imagine.
Find a local one in the yellow pages, then go knock on the door and ask someone if they'd do it.
Cash in hand I bet they'd do you it on one of thier lunch breaks.
Old 28-04-10, 12:43 PM   #92
barwel1992
^ cheers, will ask around first before buying the forks, also asked the bloke what size hole the stem is because the stem at the moment is 30mm at the bottom and 25mm at the top so if the stem is 25mm hole the sv stem wont fit i dont think
unless some one can confirm what diameter the hole in the sv yoke is for the stem (still dont have bike back)
Old 28-04-10, 01:55 PM   #93
Owenski
could always get a custom yolk made for what you require, wont be cheap but it'll be unique.
Old 28-04-10, 02:03 PM   #94
barwel1992
looking at the sv yoke i think its about 25mm at the top just waiting for the bloke to come back with measurements for the tuono yoke (rsv bottom yoke zxr400 stem and tuono yoke)
Old 28-04-10, 03:41 PM   #95
barwel1992
spoken to my dad and im very close to giving the rsv forks ago
Old 28-04-10, 04:16 PM   #96
barwel1992
will this get the sv castle nut's off, apparently they are the same as the r1 ?
LINK
Old 28-04-10, 06:10 PM   #97
fastdruid
fastdruid's Avatar
I normally use a C-spanner, that is the proper tool for it though. I don't know if that exact one will do the job but that seller is the one I bought the tools to remove the castle nuts/adjusters for the engine on the SV. I'd buy from him again (and now I've seen it I'm tempted to get one of the headrace tools from him too).
Druid
Old 28-04-10, 06:12 PM   #98
barwel1992
think i will give it ago
things seem to be Coming together now
ohh do i need a gsxr bearing seal ? or something for the top bearing ?
Old 01-05-10, 09:53 PM   #99
barwel1992
I know Own a RSV mille front end
also the seller is going to press my sv stem into the rsv yokes so will just be a slot in job (apart from the steering lock maybe)
forks have new oil and seal's nearly new ABE wavy rotor's (expensive and hard to find) and gold brembo's
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
GSXR 600 K5 forks gruff SV Talk, Tuning & Tweaking 4 17-04-07 09:36 AM
which GSXR for forks svrash SV Talk, Tuning & Tweaking 29 15-02-06 09:15 AM
