Old 09-10-09, 10:31 AM   #101
Lucas
Default Re: rear shock change
looks nice! I got one waiting to be fitted too!
are you fitting it to a curvy or pointy? asking because on the curvy, there is a metal plate that holds the battery in place (the metal plate is part of the tank hinge), which may foul the angle reservoir. Any had problems with it? I got a angle cut and not afraid to use it
cheers
This little puppy arrived safely at mine this week
Yum...yum!
Old 09-10-09, 10:51 AM   #102
Nobbylad
Nobbylad's Avatar
Going into a K8 pointy...when I buy the right bolt
Old 09-10-09, 11:13 AM   #103
cheers
You got a late GSXR shock for curvy? What is spring rate and length like compared?
Yes for some shocks you have to chop tank bracket part off (for SRAD750 shock)
Old 09-10-09, 12:32 PM   #104
barwel1992
Nobbylad i got one of them on my garage floor getting the bolt to day hofully well i orderd yesterday and the sead it will be in for to day so should be in by to night
Old 09-10-09, 12:33 PM   #105
Nobbylad
Nobbylad's Avatar
I know mate, I was gonna suggest we buy two to save on the postage, but my local guy will source me one at cost and maybe even cheaper than Robinsons (is that where you got yours from in the end?).
Old 09-10-09, 12:37 PM   #106
barwel1992
i got mine from bikers world and im picking it up cuz i fancy the ride cost £4.60 for bolt and nut bit steep but oh well
Old 09-10-09, 01:09 PM   #107
Neeja
cheers
http://forums.sv650.org/showthread.p...+shock+install
Old 09-10-09, 01:17 PM   #108
Lucas
Originally Posted by Neeja View Post
nice one, will the standard battery still fit using your bottle spacer method?
Old 09-10-09, 02:00 PM   #109
Neeja
Unfortunately not. The top edge of the battery ends up against the seat, and the seat can't be replaced. You could always hack a bit off the seat to make it work, but with the slimmer battery it all fits perfectly. If you're wary of putting a smaller battery into the bike (it does have a slightly lower capacity than stock), you can use a YB14B-BS instead of the YB12B-BS. You can also buy a cheap brand YB14B-BS, as the CCA of it is going to be miles more than the SV needs, whereas if you're getting a YB12B-BS you need to buy a decent (Yuasa/Varta etc.) one.
However, bear in mind that this is an install using a 636 B1H shock. If you've got a different one to put in the modifications may be different.
Old 09-10-09, 02:02 PM   #110
I have had C1H shock and GSXR750-SRAD one fitted with stock battery.
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
