Old 28-04-09, 01:48 PM   #111
slloyd
Default Re: Just had my 1st off
exhaust front pipe... A hammer it is then. Red circle is where the exhaust has pressed against the bolt.
Old 28-04-09, 01:51 PM   #112
Hmmm yes you're probably going to have to hack that up.
See if you can get the nut off tother side then knock it round and out of the way.
Old 28-04-09, 01:55 PM   #113
Spiderman
Where the hell am I?
Spiderman's Avatar
Whoa, only just seen this. Sorry to hear of your off and i hope replacment parts are easy ...and cheap...to come by for ya.
Glad your in 1 piece tho as that sort of damage could have put you in the hossy for a while
Old 28-04-09, 02:42 PM   #114
gralln9
hi slloyd
my mrs said do you want to borrow her cg125 for the mayday run,lol
Old 28-04-09, 02:57 PM   #115
slloyd
Gralln9, thanking your Mrs for the wonderful offer , but on this occassion I'll pass, as my body still doesn't feel 100% repaired.
Old 28-04-09, 04:31 PM   #116
Jdubya
So are you going to break or repair then?
Old 28-04-09, 05:58 PM   #117
slloyd
Well it's funny you should say that Jdubya...and mechanic has been delayed so the frame inspection has been postponed. Just spent the time removing the fairings and damaged bits and if I do repair the shopping list would be as followed:-
1. New Front Wheel
2. New Front Discs + Pads
3. New Front Left Brake Caliper
4. New Front Speed Sensor + Cable
5. New Front Tyre - Avon Viper Sport
6. New Front Forks + Springs
7. New Front Axle
8. Oil Filter
9. Front Exhaust Pipe
10. Side Stand
11. Front Motrax Mini Indys
12.Left Side Rear View Mirror
13. Glass for Right Side Rear View Mirror
14. Clutch Lever is slighty bent, so may get away with bending it.
...and that concludes the extensive list.
looking at that lot, it sounds like a lot of money.
If I broke the bike up...I doubt I could get much more for the reamining items???
Old 28-04-09, 06:01 PM   #118
Discs mashed? That's rare.
What's up with the tyre?
Speed sensor? Whole body of it mashed or just the inner/outer/what? The cable is part of the outer (sensor) part. Moulded in.
Exhaust systems are generally free or very cheap for stock systems.
Old 28-04-09, 06:34 PM   #119
slloyd
Yep, where the gold section joins the drilled section the connections have pushed out.
Speed sensor...well it's mainly the cable being severed - so I would need the out section then?
Tyre wall has split, where the wheel has cracked massivley and cut into the tyre.
Picture shows where the tyre wall is split.
Old 28-04-09, 06:36 PM   #120
Just chop the cable around the crushed but and solder it back together... seemples.
Fork springs? Have a look at yours, I've had some proper f##ked forks apart and the springs have been fine.
