Old 28-04-09, 06:37 PM   #121
Dave20046
Dave20046's Avatar
Default Re: Just had my 1st off
That's the worst wheel I've ever seen
Can't quite see the damage on the disk though. If you mean the rivets are knackered you know they can be replaced right?
Old 28-04-09, 06:39 PM   #122
If they're that badly toasted it will have damaged some part of the discs. If alloy carrier is damaged not too bad, if it's the disc itself then chuck them.
I wouldn't worry about replacing just one disc though.
Old 28-04-09, 06:41 PM   #123
slloyd
Cool, that's the cable issue sorted...
The left side spring was fine, but the right side spring is a bit out of shape.
Old 28-04-09, 06:43 PM   #124
Originally Posted by slloyd View Post
1. New Front Wheel £80-100
2. New Front Discs + Pads £120-300
3. New Front Left Brake Caliper £30
4. New Front Speed Sensor + Cable
5. New Front Tyre - Avon Viper Sport £70
6. New Front Forks + Springs £80
7. New Front Axle £10
8. Oil Filter £5 + £10 oil.
9. Front Exhaust Pipe £30
10. Side Stand Big hammer + arc welder. 2 pints.
11. Front Motrax Mini Indys Gaffer
12.Left Side Rear View Mirror Gaffer
13. Glass for Right Side Rear View Mirror Gaffer
14. Clutch Lever is slighty bent, so may get away with bending it.
So you're on the painful end of £400 there. Unless you can find a wheel/disc/tyre set cheap ish.
Old 28-04-09, 06:45 PM   #125
slloyd
Dave, on the picture the blue circles is where the disc on the other side has protruded...and the smaller circle identifies a slight bend in that area, on the other side.
Old 28-04-09, 06:46 PM   #126
Dave20046
Dave20046's Avatar
cutting back on how many things can be fixed with gaffer chris?
Old 28-04-09, 06:47 PM   #127
Dave20046
Dave20046's Avatar
Ahh they'll want replacing then, bang the good'n on ebay
Old 28-04-09, 06:52 PM   #128
Actually there should be some -ve prices on that list... scrap value of wheel... old bearings and disc etc etc
Old 28-04-09, 06:58 PM   #129
slloyd
Well, it's cheaper than trying to find upto £2k for a replacement bike, but a painful cost nonetheless.
It's looking like the "silver fox" could be missing this summer, while I start the potential rebuild.
Old 28-04-09, 07:53 PM   #130
Depends, there was a SRAD750 went on here for £650 the other week (which I should have bought... meh!)
Would probably work out cheaper to buy another cheap curvy and break the other one.
