Old 26-11-09, 08:12 PM   #151
barwel1992
Default Re: rear shock change
when i tried the sv tool it wouldent work at all just sliped off at the firt sign of presure, thinking about geting it set up properly at some point
Old 26-11-09, 08:14 PM   #152
I think an angle grinder was involved at some point
Old 26-11-09, 08:15 PM   #153
madness
Same happened to me, that's why I now use a long brass drift/bar.
Old 27-11-09, 07:49 AM   #154
Domas
Hmm modifying stock tool is a great idea. Might just work
Old 27-11-09, 11:24 AM   #155
xXBADGERXx
I think some places also make nice preload rings for stock shocks that you adjust by putting a bar into a hole
Maxton make theirs like that , maybe they will make them for standard shocks too , you can then rotate them with a "Tommy" bar .
Old 27-11-09, 07:53 PM   #156
Otherwise ask davieSV maybe he wants some new ideas of stuff to make
Old 06-01-10, 02:08 PM   #157
koss
Originally Posted by MF4 View Post
I've fitted a K6-k9 600 Gixer shock to my K5 SV, but I've also replaced the "dog bones" to raise the tail..
It's a great shock but very difficult to setup properly
I think it's waste on a SV but... it gives a good feeling on track!
This shock is 10mm lower. If I put front end from gsxr k6 600,(also 10mm lover) is it OK?
Old 06-01-10, 02:23 PM   #158
Domas
I believe that 10mm lower shock lowers back end by 20mm or so. Not sure about the exact ratio, but it should be in that direction.
Old 06-01-10, 02:34 PM   #159
barwel1992
i "think" its more than 10mm shorter to 20mm lower at back, the dog bones that i got to raise the tail 30mm were only like 5mm longer than stock (not sure how the shock linkages work in relation to the dog bones) but id think its more like 30mm drop, but im most probably wrong
Old 06-01-10, 02:38 PM   #160
koss
So I need to compesation with longer dog bons.
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
