#181 |
Yeah exactly.
Tell you what could be interesting for curvy, CBR600R 05 shock, has #600 spring but is only 310mm eye to eye. Longer clevis to extend it out to 350mm or so and it could be an interesting swap.
#182 |
Since my bikes not being used for commuting any more I'm going to be giving it some TLC, so I'm in the market for a rear shock. With me being on the very heavy side at 17 stone without gear plus numerous runs luggaged up you can guess that my shocks done for.
So would I be right in saying that I should be looking for a K3/K4 GSXR 1000 shock? Does the original battery fit if it's lifted up with some of the underside of the seat cut on a K7 pointy? Or is it easier to go with a slimmer battery? |
#183 |
yup the 03 should do you fine im 16 stone with no gear and ride with the GF on the back so about 25stone all to geather and it seems to be fine, i did raise the rear another 30mm thogh
#184 | |
#185 |
Penske and some other aftermarket ones can be modified to fit most bikes as they're a modular setup. I wouldn't bother with hagon as they're an emulsion shock and you know how well stock one works lol. Though since you can get proper spring rate it would be an improvement.
#186 |
The spring rates are very different and IIRC slightly different lengths. But as barwell says will still be rubbish due to the very basic damping in both units.
#187 |
Yes, no gain in putting a heavier spring on if you don't have the rebound damping to control it.
#188 | |
![]() As for the Penske gear, HOW MUCH!!!. £420 for the basic shock! ![]() |
#189 |
Tell me about it. But hagon is just a stock shock but rebuildable.
Want to buy penske 8981 for same price as hagon? ![]()
#190 |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
Shock spring change | andyb | SV Talk, Tuning & Tweaking | 2 | 23-03-08 03:51 PM |
To change the rear shock, do I need to remove the swing arm? | DarrenSV650S | SV Talk, Tuning & Tweaking | 13 | 28-12-07 07:42 PM |
sv 99-02 shock change | French | SV Talk, Tuning & Tweaking | 4 | 24-02-07 07:47 PM |
change of standard shock | riktherider | SV Talk, Tuning & Tweaking | 17 | 14-12-06 12:48 AM |
