#11 | |
![]() Ah yes I remember now. It's cause I know F.... all about what they are talking about. ![]() |
#12 |
Don't worry Simon.
Using telnet with an address and tcp port number is an easy way to check routing firewalls and existence of a remote listener service. for instance if you were having problems talking to the forum and wanted to check if there was something wrong at a network level. a quick "telnet forums.sv650.org 80" from a command prompt would check there is nothing blocking the routing etc.
Not Grumpy, opinionated. |
#13 | |
The Sick Man
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#14 |
True, true TSM. I wasn't going to go into the protocol dialogs as I think we have already ventured into extreme geekdom simply by knowing telnet can be used for anything more than a terminal connection to a geeky computer system.
although in my example you would get the connection. This to me is enough to indicate that the remote listener has accepted the connection and forked the appropriate handler and thus we again venture into geekdom. Nuff said. It is a very useful diagnostic tools only used by yup you guessed. Geeks
#15 | |
The Sick Man
Ahh yep, too geeky Anyway for everyone else, in a telnet session, as long as it does not close imediatly or just stick on "Connecting to ....." but moves to somthing else then the remote computer is there, if it does the prev mentioned things then there is an issue. Just a note, on vista you cant put telnet into the run type box in the start menu, it does not work, you have to type "cmd" first then type the telnet bit in from the command line.
Fax to Email | Manguish | Idle Banter | 5 | 20-06-08 07:51 AM |
email help ? | Ratty | Idle Banter | 10 | 22-04-06 01:50 PM |
