#11 | |
if you have the holes drilled in your brake bolts then you have 2 have them wired but if thers no holes in them then you dont have 2 have them done! |
#12 |
Oh and your best not putting holes in them as it only cause's hassel when wheel changeing etc...
#13 | |
Personally I wire mine simply because I couldnt be arsed threadlocking them every time I switched wheels. There's actually more information in the regs about body jewellery than there is about brakes ![]() |
#14 |
as far as i no it works out if you have the holes in them then they need lock wired if thers no holes in them then lock wireing isnt needed on them!
#15 |
I've drilled my caliper bolts then I have two R clips linked together with lockwire, one clip through each bolt then just pull them out at wheel change time.
#16 |
Lockwiring caliper bolts is a Isle of man and other proper road racing thing.
NO requirement for it on track based racing |
#17 |
When I say that's all I do, I mean that's all I do to the oil filter. Obviously sump plug and oil filler cap etc are lockwired as well. Never lockwired caliper bolts either, which is just as well given the amount of times I change wheels over a weekend when weather is changeable.
Safety Cameras..... Safety my A?$e | SoulKiss | Bikes - Talk & Issues | 39 | 22-04-08 09:36 PM |
Health & safety look away now..... | embee | Idle Banter | 13 | 25-03-08 09:30 AM |
oil, filter and air filter change | doe | SV Talk, Tuning & Tweaking | 10 | 17-04-06 01:29 PM |
Safety ad | Anonymous | Bikes - Talk & Issues | 6 | 07-08-05 07:58 PM |
To filter or not to Filter.....are you feeling lucky? | Magoo | Bikes - Talk & Issues | 40 | 02-12-04 05:17 PM |
