Old 25-02-08, 07:06 PM   #11
Defender
Default Re: Anti-Fog and Washing Up Liquid
I have to ride with the visor 1/2 an inch from closed otherwise the visor is full of condensation, although the lid has a vent at the front.
TBH its never been an issue leaving the gap.
Old 25-02-08, 07:09 PM   #12
DoubleD
use white vinagar to clean inside of visor, one of Baph's recomendations to me and it works a treat, no fog at all.
Old 25-02-08, 10:54 PM   #13
I'm_a_Newbie
Originally Posted by teriyakimonkey View Post
You may have found your answer right there!
Buy yourself an Arai Condor and use just the plain visor and see how you get on. They mist up really badly, even with the visor slightly open. Washing up liquid has made a big difference.
Tim.
Old 25-02-08, 11:00 PM   #14
I'm_a_Newbie
Went to HG at lunchtime to have a look at the Foggy breath guard. These don't go well with the Arai Condor it seems. The fixing for the breath guard will cover over the chin vent holes. If the Condor had a screen vent as well it would be OK but it does not. As I already use a neck tube that cuts off a lot of ventilation the Foggy could make things worse.
Does anybody use one of these with a Condor? How do you rate them with the Condor?
Thanks
Tim.
Old 25-02-08, 11:19 PM   #15
FG1
When I am on my way to work in the winter mornings at about 05:30 its quite easy to mist up the visor but......
Learning to control your breathing can actually help loads. Think about your breathing and make it slow and gentle. Breathing through the nose helps also.
Mind you, if you are happy opening the visor a tad, then do that.
Old 26-02-08, 12:55 AM   #16
ethariel
ethariel's Avatar
Been using a Condor for about 3 years now.
Got some pink stuff (anti fog) around then but its almost all gone so it's back to the Bob heath demist spray, not great but use it before u ride and its not too bad really.
Condor tho mists up really bad and as i cant just up the visor in fog (i wear glasses) or rain it's a real pain!.
Seriously, if you can affors it, go pinlock (way superior to a spray or WUL) or a different Arai lid.
Eth
ethariel is offline   Reply With Quote
Old 26-02-08, 09:52 AM   #17
JamesMio
I've got a Condor / PinLock combo and find it great, 99% of the time. The only bit that ever fogs up is the bit right under my nostrils, and even then it's rare.
It does get pretty damp in there from condensation though I must admit.
"That **** on the push-bike."
Creatomatic
Old 26-02-08, 06:55 PM   #18
I'm_a_Newbie
Thumbs up Re: Anti-Fog and Washing Up Liquid
Correction to my earlier post, the Condor does have a screen vent. It is moulded into the polystyrene liner. Trouble with this is, if like me you carry your lid around by putting your hand through the screen opening and holding the chin area, it squashes this vent closed.
I think I will put couple of soft platic wedges in there to keep it apart from the outer shell, and then buy myself a Foggy Breath Guard.
I think this coupled with the Washing Up Liquid will work really well.
Tim
Old 26-02-08, 06:58 PM   #19
I'm_a_Newbie
Thumbs down Re: Anti-Fog and Washing Up Liquid
To those that suggested that I get a Pin-Loc insert, I have one. As I pointed out in the original post, I find that this cuts down nightime vision on unlit roads.
Tim.
Liquid Metal DarrenSV650S Idle Banter 42 06-04-09 03:31 PM
Liquid Nitrogen phil24_7 Idle Banter 25 10-07-08 08:49 PM
Anti British and anti American threads - crass and boring Ed Idle Banter 40 13-06-06 06:08 PM
The most powerful liquid in the world Jdubya Idle Banter 6 03-04-06 07:56 AM
washing the sv will SV Talk, Tuning & Tweaking 37 02-05-05 08:21 PM
