Old 06-03-08, 07:25 PM   #11
scottjames
Default Re: steering damper.
cheers ill try tht. to be far i woud it up cos i had people on the back, ill try with just me. thanks. scott
Old 06-03-08, 08:57 PM   #12
ASM-Forever
I like the effect my damper provides, although i must admit i initially purchased it for aesthetic reasons.
I've ridden mates bikes without a damper since i had mine fitted and the steering seems a bit 'wrong'.
IMO unless you have the money to throw away then its not worth it. As others have suggested spend money inside the forks and on the rear shock.
After all, you'll only be polishing a turd.
<Runs off sniggering>
Old 07-03-08, 01:54 PM   #13
Dangerous Dave
Steering dampers just mask problems! The most common is with riding style, but if you need a damper because of the bike and not you riding technique then sort out the suspension!!!
A good damper will cost more than getting your handling sorted!
Old 07-03-08, 01:59 PM   #14
Alpinestarhero
A wobbly SV could be due to the soft suspension. I've had shakes and wobbles, nothing to write home about though.
And certainly never anything to warrant a steering damper, even high-speed wibbles due to top-box style areodynamics
Even with maria pillion AND the damn topbox, any wobbles have been nothing to get excited about.
Save your dosh, and instead source a new rear shock and a new set of fork springs. Much better...and possibly cheaper!
Matt
steering damper. TOY40 SV Talk, Tuning & Tweaking 5 24-06-08 12:32 PM
steering damper maultin SV Talk, Tuning & Tweaking 19 16-06-08 06:43 PM
Steering Damper colin35racing Stuff Wanted 7 03-03-08 11:31 PM
Steering lock for Steering damper Sideshow#36 SV Talk, Tuning & Tweaking 8 30-08-07 11:18 PM
steering damper misssurferrosa SV Talk, Tuning & Tweaking 7 16-07-05 11:46 PM
