#11 | |
#12 | |
ditto +1 ![]() |
#13 |
Just given mine the deep clean...again - the full 'wheels off, all bodywork off' type clean.
If you're worried about the condition of the rear brake pistons, leave one old brake pad in and pump them out a little way before removing the pad and scrubbing them with a toothbrush and WD40. If you see nasty rust pits on the pistons then it might be time to replace the pistons and seals. If not, clean the dirty WD40 off with brake cleaner, dry with a clean rag and regrease the inside of the caliper with a smear of red rubber grease before pushing the pistons back and fitting the new pads. |
Rear brake caliper pin | twopots | SV Talk, Tuning & Tweaking | 14 | 22-12-08 06:48 PM |
Rear brake caliper | Baz | SV Talk, Tuning & Tweaking | 4 | 05-08-08 05:14 PM |
curvy swingarm and rear wheel | riktherider | SV Talk, Tuning & Tweaking | 2 | 27-02-07 06:36 PM |
Rear Brake Pipe rubbing on Swingarm. | david-m | SV Talk, Tuning & Tweaking | 6 | 08-08-06 04:46 PM |
Rear Wheel Cleaning | DanDare | SV Talk, Tuning & Tweaking | 23 | 02-08-06 09:51 AM |
