Old 09-12-08, 09:57 PM   #11
Sean_C
Default Re: Trailtec Vector Digital Speedo
Oh right. I must be thinking of something else then.
The vapor is a nice little unit- have you got the idiot light surround?
Old 09-12-08, 10:00 PM   #12
lawson17
The only downside I'm aware of is that you lose the ability of fault diagnosis. But all the original wiring is intact so I could plug it in if need be.
I was tempted with the idiot lights but decided they weren't necessary, I have however installed neutral and oil pressure indication LEDs.
Old 09-12-08, 10:02 PM   #13
Sean_C
I keep meaning to wire up an oil pressure LED.. not sure I need it, oil is checked every time I ride the bike and it's a well maintained bike. I wired up neutral, high beam, high reserve and indicators. Also a posh LED for low reserve..
Old 09-12-08, 10:04 PM   #14
lawson17
Ha Ha! A posh one, I like it!
I wonder if its possible to put one in for the pointys fuel level? Hmm...
Old 09-12-08, 10:23 PM   #15
Sean_C
I found that the two signals for high and low went into the clocks separately, but operated one light, solid and blinkered (I can't remember which way round). So I wired up the reserve light for the vapor as the high reserve and the posh LED as low reserve.
Luckily I wired them the right way round, otherwise I would've had to rewire them!
Speedo accuracy. If your '99 650 is showing 37mph on the speedo. lloyd_christmas SV Talk, Tuning & Tweaking 14 12-06-08 12:02 PM
M25 going digital flibble Idle Banter 6 19-02-08 01:50 AM
Digital SLR Advice please! trickywoos Idle Banter 7 21-11-07 10:49 PM
Digital Camera Grinch Idle Banter 3 20-04-07 02:52 PM
Digital SLR...Which one? Jdubya Idle Banter 20 30-09-06 05:54 PM
