Old 04-05-08, 10:57 PM   #11
sv650k4
Default Re: is ther anyway of doing away with the TIP OVER SENSOR?
i was looking 2 completely do away with it but i dont really mind alot if i cant.
but i would be happy 2 no more about removeing the barrel and stuff.
Old 04-05-08, 11:00 PM   #12
I've told you how to do it
If you want more info then I'll check colours in wiring diagram in the morra.
IIRC theres a grey one and a pink one, ignore them. Red and orange are main live that need putting to some sort of switch. The black/white and the final wire need a resistor between them.
Old 04-05-08, 11:14 PM   #13
sv650k4
ryt so the conector that comes out of the loom that the barrel plugs into ther will be a red and orange thats the ones that i would need 2 route up 2 the switch gear if that wot i want 2 wire it 2 or a seprate switch even.
then the other 2 wire need some sort of resistor in them or something???
cheers.
Old 04-05-08, 11:17 PM   #14
I need to look at a wiring diagram before I answer that, I don't know how much current the running circuits draw.
Old 04-05-08, 11:20 PM   #15
sv650k4
ryt ok no problem if you can find out please and let me no what way it works/wot i need 2 do that would be great!
Old 04-05-08, 11:23 PM   #16
Remind me tomorrow as I'm forgetful...
Old 04-05-08, 11:24 PM   #17
sv650k4
no problem il send you a Pm sometime 2 moro.
thanks.
Old 05-05-08, 04:43 PM   #18
Right... looking at the wiring diagram in haynes, it appears that the handlebar switch only runs the coils + fuel pump. ECU system has it's own fuse which appears to always be live (when ignition on)
So... I have no idea whether the handlebar switch will handle the current draw of both ignition and fuelling.
If you want to do this, then run the fuel system on a relay to be on the safe side... or try it and see what happens, but don't cry to me if it burns the handlebar switch out.
p.s I'm never making a wiring loom for a pointy
Old 10-05-08, 01:40 PM   #19
http://www.mototuneusa.com/gsxr_tip_over_switch.htm
worth a look
Lambda sensor k7/k8 DANINPLYMOUTH Bikes - Talk & Issues 0 20-04-08 06:03 PM
Speedo sensor. phil24_7 SV Talk, Tuning & Tweaking 5 19-12-07 08:41 PM
Speed Sensor for a K3. creamerybutter Stuff Wanted 0 26-02-07 10:34 PM
Where could i put a temp sensor? svrash SV Talk, Tuning & Tweaking 17 13-01-07 12:16 AM
speed sensor nelsont SV Talk, Tuning & Tweaking 4 19-07-06 12:22 PM
