Old 16-06-08, 05:34 PM   #11
sinbad
Default Re: SV's max lean angle?
Originally Posted by Lucas View Post
Did some homework, think its 28 deg measuring from ground to bike
http://img391.imageshack.us/img391/852/svlean2op3.jpg
So the standard bike can lean 68 degrees before touching down? Seems a bit high to me.
edit......yes, of course, compression. How much suspension travel/tyre deformation would you expect whilst at full lean? (How much would the "ride height" actually drop?)
Old 16-06-08, 05:39 PM   #12
amarko5
erm 62 and 28 made 90 when i went to school but that is strictly uncompressed as if you just laid the bike over, all the forces involved i would guess any better than 45 as standard would be exceptional.
it aint no moto gp bike
Old 16-06-08, 05:42 PM   #13
sinbad
lol typo, my bad
Old 16-06-08, 05:44 PM   #14
Blue_SV650S
Yes, 45deg compressed is about the mark (as derived from my Phoenix photos*). Obviously the faster the corner, presumably the more the suspension compresses, so even this is variable.
*Phoenix does have peg raiser plates on it - but its been argued, in practice, these give no clearance benefits.
Old 16-06-08, 05:53 PM   #15
sinbad
I'm not sure, you turn tighter in slower corners, and achieve approximately the same lateral 'g' on the limit whatever the corner. Camber could compress the suspension more because it would allow for higher cornering speeds and higher 'g', but then it would also allow for more ground clearance so it probably evens out.
Old 16-06-08, 05:56 PM   #16
John 675
does this answer your question? i know its not a curvy but it cant be too different can it? my pegs dragged for a second or two
Old 16-06-08, 09:07 PM   #17
Tim in Belgium
Or on a curvy, standard height suspension and pegs:
Hero blobs just on and off scraping.
Apologies for the pic whoring
Old 16-06-08, 10:14 PM   #18
drag
Originally Posted by Tim in Belgium View Post
Was anybody else screaming " Quick Tim go up the inside !!!!"
no .. just me then, i wonder how far i managed to put mine over this weekend, it felt like i was practically sideways
Old 16-06-08, 10:48 PM   #19
Dave The Rave
Originally Posted by zadar View Post
no.
angle changes depending on where suspension is in stroke.
Wasn't the question maximum leaning angle? I read that as the biggest lean possible?
Old 16-06-08, 11:11 PM   #20
KeithCRM
I reckon it's around 50 deg on mine. Measured the angle of a well ground foot peg using a spirit level with one of those adjustable dials. 12st rider with standard pegs and suspension.
Mine's an 'S' which I think has slightly higher pegs than the naked.
Is this a lean angle gauge? hera Bikes - Talk & Issues 3 16-02-09 12:02 PM
Lean angle... the_lone_wolf Idle Banter 4 07-05-08 07:50 PM
lean angle equipment hera SV Talk, Tuning & Tweaking 12 05-04-08 07:24 PM
Lean angle anyone? Treacle Photos 19 14-02-06 03:58 PM
