#11 |
I'll second the £100 Halfords kit as linked to above. Really worth the investment if you can stretch to it and it will last a lifetime.
I got the same one (or thereabouts) a couple of years ago and have really abused it to be honest, and its great. I've had a few bits replaced that really were broken through misuse (3/8 extension on a 3ft breaker bar with 1/2" adaptor trying to undo a alternator pully). |
#12 | |
#13 |
24mm. is that all!
36mm on my little GSXR. but 110Nm is still a lot to undo with a standard socket wrench. So I guess the breaker bar still stands. Never done a pointy SV. so it was a guess as to the actual torque. hence the "(I Think)" bit. To add to what tools. a stand is useful. You pays your money, takes your choice, ABBA/NWS type. or paddock type. recommend if buying paddock ones you go for the front headstock type and hooks/bobbins rear. Picking up on Viney's post. I thought SV's had Phillips not posidrive screw heads.
Not Grumpy, opinionated. |
#14 |
Thanks for all the advice guys.
I don't really wanna spend £100 straight off the bat on a socket set, I'd rather build up stuff as and when I need it if possible. My first task will be an oil / filter change, followed by putting the pillion seat back on the bike, and then probably chain adjustment. With that said, and a couple of recommendations for Sealey, is the following ok? Sealey 3/8" square drive 10-100nm torque wrench: http://cgi.ebay.co.uk/SEALEY-TORQUE-...d=p3286.c0.m14 SEALEY AK692 Socket Set 45pc 3/8” Sq Drive Metric: http://cgi.ebay.co.uk/SEALEY-AK692-S...6.c0.m14.l1308 |
Basic Questions | benp1 | Bikes - Talk & Issues | 21 | 24-09-08 04:59 PM |
basic tools | Corf | SV Talk, Tuning & Tweaking | 27 | 18-09-08 04:37 PM |
Some basic HELP with EXCEL pls | 600+ | Idle Banter | 4 | 02-10-07 01:59 PM |
basic mechanical Qs | grecian9 | SV Talk, Tuning & Tweaking | 2 | 09-08-06 09:43 AM |
some basic questions. | Warren | SV Talk, Tuning & Tweaking | 6 | 12-04-06 09:19 AM |
