#11 | |
#12 |
Not at all it's just a micro switch... and better yet, it's knackered anyway so you've nothing to lose!
#13 |
I'd take the switch off the bike (take wires off, 2 screws hold the switch on as I recall), and simply squirt it full of WD40 or contact cleaner or similar. Work the switch and keep squirting the stuff in through the little vent hole.
Chances are it'll clean the contacts up enough to start working again. They are designed so the contacts wipe slightly as the switch works which in theory keeps them clean, but dirt can build up and prevent contact. Give it a try. Nothing to fear!
#14 |
Thank's guys I'll give it a try. My next reply will be one of two things, either
#15 |
Finaly managed to get around to looking at the switch. Tried WD40 and no luck, opened up the switch and all the insides just fell out, anyone know where I can buy a new one, or what is this, "pressure switch banjo bolt", more to the point is it easy enough to fit.
#16 |
The Banjo Bolt Switch option is not for you I am afraid.
It would require you to bleed your brakes, and from your post, I dont think you are up to that just yet. Go to any bike breakers or scrap-yard, as mentioned, its a common part for any Nissin brake system, (so any Japanese bike). Alternatively, any bike dealers should be able to get you one.
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#17 |
Its Brake
#18 |
#19 |
Thank's for all the help guys, got a new switch on and works fine.
Cheers ![]() |
My Curvey's still for sale (break for parts or fit a new front end) | jamessunhill | For Sale - SV's and SV related items | 1 | 13-08-08 11:56 PM |
Break light, by which I mean it's broken, or do I? Perhaps I meant BRAKE. | drag | SV Talk, Tuning & Tweaking | 7 | 23-08-07 11:22 PM |
Should I break my Curvy SV? | Mags | SV Talk, Tuning & Tweaking | 11 | 13-08-07 07:28 PM |
Attempted break in - again! | gettin2dizzy | Idle Banter | 31 | 26-05-07 10:41 PM |
Crash.NET - Stoner makes a break, Capirossi back to the front. | NewsBot | News | 0 | 20-04-07 08:10 PM |
