Old 24-07-08, 10:55 AM   #11
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: Really hot rear brake disc
Originally Posted by Sosha View Post
It ain't "Juddering" it's "gently pulsating" (ooer)
what he/she said^^^
could be described as a throbbing perhaps
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 24-07-08, 11:03 AM   #12
Sosha
or "Flexing"....
Old 24-07-08, 11:04 AM   #13
Warthog
Well what ever it is, I don't think the disc is warped yet, jus that it is hot and might warp soon! I am going to go outside and take the caliper off, see if I can see anything...
Old 24-07-08, 12:59 PM   #14
Warthog
fixed! I think
I dismantled eventually using cruddy work tools, and found that (bear with me as I don't know the right names for things!) the little thin metal assmbly that sits behind the pads, kind of springy, had gotten mashed when the new pads were put in, so half of was bent in sticking between the pads. This was then rubbing against the top of the brake disc, so much so it had worn a shiny disc-sized groove into it. This was then superheating the disc and making my pads go a rainbow colour. I took it out, straightened it with some pliers and put it back in behind the discs. It seems well out of the way now, but when I tested it up and down the car park, I was braking heavily, making my rear wheel skid, and so when I felt it it was hot again . Now I just have to let them cool down, then ride normally and hopefully it will be fine. Rear wheel spins fine again now too.
Question: Do I ring up the mechanic in question and bollock him or ask for a discount?? It was an honest unlucky mistake, but we were spinning it and both heard the metal noise at first...
Old 24-07-08, 01:02 PM   #15
the_lone_wolf
Captain Awesome
brakes will get very hot when you use them, jump off the bike after a gentle ride and spit on your finger then quickly touch the disc, it'll probably boil and hiss because the disc is so hot. sounds like you found the cause
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 24-07-08, 01:12 PM   #16
petevtwin650
Call them and at least give em a b0ll0cking, then ask for a discount
Sean C had a similar thing with his front pads on his last fateful rideout. Mechanic there had assembled one of the fronts wrongly. Luckily Tilt sorted that out for him. Make you wonder about these "mechanics" sometimes.
Old 24-07-08, 01:18 PM   #17
Alpinestarhero
Definatly; there was a guy at uni with a bandit who had his bike serviced, and the mechanic hadnt torqued up the rear caliper bolt correctly. It had vibrated loose, then the whole caliper was flapping about on the wheel.
I only let my dad fix my bike, and I am trying to learn as much as I can to be able to do it myself - I think possibly I could trust a few of you lot on here aswell. I find it very hard to trust anyone with fixing something on my bike which, if it isnt done properly, could result in an accident and my injury.
Old 24-07-08, 01:28 PM   #18
Warthog
http://alpha-sports.com/suzuki_parts.htm
According to this it is number 4 part the ".spring, pad" on the rear caliper that was mangled.
Old 24-07-08, 01:30 PM   #19
Warthog
Well I try and do most stuff myself, but as he was changing the tyre, he noticed the pads were gone so I thought lets just bung new ones in as I have an MOT booked tomorrow morning. Just thought he would do it right!
Old 24-07-08, 01:32 PM   #20
Alpinestarhero
Na, I'm not questioning you for a second I would expect someone to do it properly too, and not only that, to investigate any abnormalities after doing something...like metal-on-metal noises
rear brake disc pointy kcowgergmm SV Talk, Tuning & Tweaking 1 17-11-08 07:54 AM
Rear Brake Disc For A Curvy 21QUEST For Sale - SV's and SV related items 0 17-08-08 04:19 PM
Rear brake disc for curvy andyb For Sale - SV's and SV related items 0 27-04-08 06:02 PM
Curvy Rear Brake Disc: MrMessy SV Talk, Tuning & Tweaking 6 26-11-07 06:56 PM
Smaller rear brake disc and caliper.... anyone? Vtwinlover SV Talk, Tuning & Tweaking 2 17-07-05 07:28 PM
