Old 26-08-08, 08:04 PM   #11
TEC
TEC's Avatar
Default Re: Justi fitted a standard exhaust. Pipe sealed with silicone. How long before I start motor?
Originally Posted by teriyakimonkey View Post
.. Says on care sheet it goes up to 140 degrees ....
Is that C or F If the later then thats probably a whole lot cooler than your exhaust will get
I am behind you
http://wildwesternadventures.com/
TEC is offline   Reply With Quote
Old 26-08-08, 08:53 PM   #12
monkey
That'll be centigrade.
Old 27-08-08, 04:50 PM   #13
TEC
TEC's Avatar
In that case ....
Originally Posted by Dangerous Dave View Post
...Proper gasket silicone is the stuff to use.
Sounds like thats what you've got So should be ok
I am behind you
Old 27-08-08, 05:04 PM   #14
Durbs
I used bathroom type silicone. Meant to take 24 hours but it's such a thin layer in there.
Bathroom silicone! Are you serious? Thats gonna toast big style, why didnt you get exhaust sealant????
Old 27-08-08, 05:25 PM   #15
monkey
Because Mr Durbs I was told either on here or another forum or in person (I can't remember which) that normal bathroom sealant is fine for sealing a sleeve.
Well I'm not going to change it now so I'll report back next week after I've given it a good run. If it all shoots out then so be it. If it doesn't then so be that.
exhaust Silicone/sealant anyone? Lucas Soho Massive 9 24-04-09 02:48 PM
Beaulieu motor museum in southampton... anyone been? and more importantly - how long does it take to get around it? Paul the 6th Idle Banter 10 23-01-09 11:39 PM
fitted alarm now won't start. stuballs SV Talk, Tuning & Tweaking 4 17-05-08 05:58 PM
Refitting standard pipe: link pipe? Jay1 SV Talk, Tuning & Tweaking 6 17-04-08 09:51 AM
Difficult cold start (and loose exhaust pipe) owennewo SV Talk, Tuning & Tweaking 10 18-11-05 07:01 PM
