Old 02-09-08, 11:43 AM   #11
puthsardarade
Default Re: SV650S Trying to start - advice please?
Originally Posted by Dangerous Dave View Post
Any further diagnosis you can pass on to us mate?
Was the engine trying to turn over but slowly started to die, if so charge the battery.
The spark plugs themselves I wouldn't have thought would be the problem assuming the bike was has been serviced in the past 10 months?
Water in the front plug is common, as mentioned above, but that would make it run on one cylinder so it should still at least start.
The battery appeared to be fine and its fairly new along with the reg rectifier. I tried it around 15-20 times before I gave up as I was running late for work, the battery had not drained at that point.
Another interesting observation...when I parked it up at night, the steering turned to one side really easily as if it was loose! My wires had been cut a while a go so they have been taped together, but I suspect the tape might be wearing especially as it was not professionally done.
From the comments I've had so far: sparks, flooding due to drain, wiring related appear to be the possible causes?
As i'm quite new to biking could you advise where exactly I should try and check and what I should be looking for?
Thanks,
G
Old 02-09-08, 11:56 AM   #12
hovis
Thanks,
G
i would check the wires first
Old 02-09-08, 12:23 PM   #13
Biker Biggles
Biker Biggles's Avatar
Default Re: SV650S Trying to start - advise please?
Aha Dr Watson the plot thickens.Dodgy wiring repairs mut be a suspect here.
Old 02-09-08, 04:15 PM   #14
Dangerous Dave
Aha.... I would make this the first place to look!
Old 02-09-08, 08:04 PM   #15
sibbo
wd 40 everthing electrical if this fails send me your phone number and ill try drop round and look at it for you i live near the airport cant promise any thing but will show you what to test ok
Old 07-09-08, 05:46 PM   #16
puthsardarade
Hi,
Finally managed to resolve the problem, it was an issue with the wires. Appears to start and run fine now. Thanks to sibbo for coming over to try and help and thanks for everyone who responded.
G
My SV650S Curvy won't start. Ash_sv650 SV Talk, Tuning & Tweaking 24 27-06-08 04:51 PM
SV650s won't start Say_Cheese Bikes - Talk & Issues 9 19-12-07 01:30 PM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
advise for a new guy? jay boi Idle Banter 23 10-04-07 03:57 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
