Old 13-09-08, 05:07 PM   #11
Dave20046
Dave20046's Avatar
Default Re: best way to remove carbs?
does anyone know the ration of coolant to water I need to use?!
Old 13-09-08, 05:11 PM   #12
Dave20046
Dave20046's Avatar
gixxer manual says 50/50, would I be safe to do that?
Old 13-09-08, 05:31 PM   #13
Blue Flame
Blue Flame's Avatar
Buy a pointy
Triumph Sprint GT 1050 -Sexy Phantom Black; Powerbronze Screen
Previous >> K3 SV650S - Candy Copper;Lower Fairing Set;Fender Extender; Powerbronze Screen; HEL Braided Lines;
Blue Flame is offline   Reply With Quote
Old 13-09-08, 05:53 PM   #14
Dappa D
not sure what the ration is fella....
but can tell you that the ratio is the same...50/50...
haynes also says if your bike is exposed to below minus 30 u can go upto a maximum of 60 antifreeze and 40 distilled water....
Old 13-09-08, 06:26 PM   #15
Dave20046
Dave20046's Avatar
Nice one - did it at about 50/50.
Just haveing trouble geting the airbox back on now Won't seem to press down enough over the rear carb.
Old 13-09-08, 06:27 PM   #16
That can be fiddly... I leave the back rubber thing on the carb, then fit it at the front, then push the airbox onto the rubber.
Old 13-09-08, 06:31 PM   #17
Biker Biggles
Biker Biggles's Avatar
Putting the airbox on right is important as it affects the mixture if its not right.Its easier if you take out the airfilter so you can see the rubber seals.You need to ensure the lip comes up into the airbox on each carb and I use a screwdriver to ease the seals over the edge of the airbox.
Hard to describe but fairly obvious when you do it.
Old 13-09-08, 06:39 PM   #18
Yup. One of my favourite 1337 SV inventions is the wee spacer I fitted between the airbox and tank- it pushes the airbox down preventing it from coming off, and also stops me from stupidly putting hte tank down and bolting it all up if I've not got the airbox or carbs sitting right. I am a tuning god.
Old 13-09-08, 06:41 PM   #19
Dappa D
id say that was a good description fella, very helpful too as im rejetting tomorrow, and that little nuggut of info will come in very useful
Old 13-09-08, 09:10 PM   #20
K
Alternatively you could just hit the whole thing repeatedly, very hard, with a hammer...
... the Carbs will come off eventually. Time required entirely dependant on the amount of force used.
Oooohhhh - you want it to still work afterwards.
How to remove virus? StreetHawk Idle Banter 5 28-08-08 03:07 PM
Help to remove fairing 600+ Bikes - Talk & Issues 0 26-05-08 12:48 PM
What's it for and can I remove it? mastiffmat SV Talk, Tuning & Tweaking 3 09-11-05 11:05 AM
Please remove your helmet Clunk Bikes - Talk & Issues 72 26-07-05 02:44 PM
Sorry old. Please REMOVE Richie Bikes - Talk & Issues 4 19-03-05 09:59 AM
