Old 17-09-08, 11:33 AM   #11
petevtwin650
Default Re: basic tools
Which bike do you have ?
If its a pointy you may have overlooked the toolbox.
Mind you the contents if it IS there are pretty bad and worth changing if you can, but it does let you know what the manufacturer intended you to have,
What year Sv do you have?
Old 17-09-08, 11:38 AM   #12
Corf
cheers guys. trip to halfords on the weekend me thinks. think cheap ones will suffice for the amount of use they will receive. maybe when i get a place with a garage i will venture for more/better tools and hopefully start doing more with own bike.
Old 17-09-08, 11:50 AM   #13
Dappa D
+1
not having a garage is a right PITA!!!
Old 17-09-08, 01:56 PM   #14
Sideshow#36
I have a spare OE SV650 tool kit if you are interested.
Old 17-09-08, 02:00 PM   #15
Corf
what can be done on the bike with the OE tool kit?
Old 17-09-08, 02:12 PM   #16
MiniMatt
Assuming the OEM tools don't fall to pieces, bend, generally melt (which is a big assumption) you can do a fair amount with them in theory at least. From recollection there's stuff in there to take everything off but the front wheel (but in practice you'll need a bodged breaker bar for some, and a torque wrench if you want to put it back together at correct torque). There's a C-spanner for the rear bouncy and a plug wrench thingy as well. Don't think there's an oil filter wrench in there but if you really really can't get that off by hand I guess there's the old screwdriver trick (but if you can't get it off with that you're left with a holed oil filter).
Old 17-09-08, 04:20 PM   #17
jambo
jambo's Avatar
This, right here is important. It changes what you're likely to need, and where it's likely to be hidden.
Jambo
Old 17-09-08, 04:24 PM   #18
Corf
i have K4. may it be hidden elsewhere?
Old 17-09-08, 04:28 PM   #19
Baph
It should be under the battery, accessed from the left side of the bike (as if you were sitting on it). There's a panel that pops off near the shock.
I now have my scottoiler in there though.
Old 17-09-08, 04:30 PM   #20
jambo
jambo's Avatar
I believe from K4 (or perhaps K5), instead of being under the seat the tool kit was in an extra box accessed from the left hand side of the bike, located just behind the rear shock.
1) Does your bike have this box?
2) Is there anything in it?
Jambo
Basic Questions benp1 Bikes - Talk & Issues 21 24-09-08 04:59 PM
New SV owner, basic tools. lazymanc SV Talk, Tuning & Tweaking 13 25-06-08 01:21 PM
Some basic HELP with EXCEL pls 600+ Idle Banter 4 02-10-07 01:59 PM
basic mechanical Qs grecian9 SV Talk, Tuning & Tweaking 2 09-08-06 09:43 AM
some basic questions. Warren SV Talk, Tuning & Tweaking 6 12-04-06 09:19 AM
