Old 01-10-08, 06:40 AM   #11
Dangerous Dave
Default Re: V Strom Handling Issues
Originally Posted by ScatmanJack View Post
Panniers were fairly evenly loaded but had no issues at 80/90mph previously, only if I pushed it over 100mph.
That doesn't really cause the front end to wobble, adding weight to rear does and you are doing this with the panniers. They are acting like wind brakes at higher speeds which is pushing down on the rear and lightening the front.
Has anyone fitted a steering damper to these bikes, and do you think it would have helped prevent the problems I had.
Steering dampers only mask the problem, your problem is due to the suspension if the chassis is straight.
New rear tyre but same old one on front - any potential handling issues? Paul the 6th Bikes - Talk & Issues 18 24-11-08 05:04 PM
Handling issues - slight wobble - stability Zubanoid Bikes - Talk & Issues 4 09-05-08 07:11 AM
Anyone had a V-Strom 1k? ukgooner Bikes - Talk & Issues 13 25-01-08 06:20 PM
650 V-strom The Basket Bikes - Talk & Issues 3 24-01-07 02:38 PM
GSXR Front End Conversion Handling Issues Mesomorphman SV Talk, Tuning & Tweaking 8 10-09-06 01:46 AM
