Old 05-10-08, 08:29 PM   #11
TheShadow
Default Re: I need help - Bike wont idle.
Originally Posted by Biker Biggles View Post
Try pulling the plugs out to see if one or both are running rich.If so it will probably be the chokes,or it could be a clogged up air filter.Also check the breather pipes that go from crankcases to airbox.These can come adrift and cause rough running.
Air filter looks ok but as a precaution i have purchased a nice new one of ebay which i should have on monday.
I will check the plugs to see if either is running rick i presume this will at least tell me which carb needs working on if any.
I will check the airbox breathers tomorrow and report back.
Do the carbs have to be removed to check the plungers? (Sorry i appear to have a fobia about removing the carbs!)
Old 05-10-08, 08:35 PM   #12
Yes really, it's possible without I suppose but front one is a right rse to get to!
Old 05-10-08, 08:39 PM   #13
fizzwheel
fizzwheel's Avatar
Its much easier if you take the carbs off and its not hard to do so. Otherwise to get at the front plunger screw involves a huge amount of faffing about.
Old 08-10-08, 02:05 PM   #14
TheShadow
Another bit of information that i completely forgot about.
When going over large bumps or say the crest of a hill the bike drops in power then gives a mighty back fire. I think this could be related any ideas?
Bike wont start. I Need help please chunkytfg SV Talk, Tuning & Tweaking 3 13-03-08 11:53 PM
Why wont my bike rev? Peetee650 SV Talk, Tuning & Tweaking 4 14-06-07 05:02 PM
Help bike wont turn over aarond SV Talk, Tuning & Tweaking 6 06-05-07 03:08 PM
bike wont idle bcsv650s SV Talk, Tuning & Tweaking 5 12-05-06 04:37 PM
My bike wont idle. Freeloader SV Talk, Tuning & Tweaking 6 10-02-06 06:12 PM
