#11 |
The Sick Man
The LED is oil pressure not oil level, by the time it comes on its too late if you are indeed running the bike low on oil, but somtimes its usefull for total loss of the oil, like if the oil pump dies or the oil cooler spings a leak.
The light with the can on it is the oil pressure and goes out once the bike is started, because the pump is running), the led tends to be the water over temp and that does not come on unless the water overheating.. SVs seem to vary on their oil usage, some use lots others not so much also over time it seems to change too. My SV uses what i consider to be lots of oil, 1L or so every 1k, but im always on top of it, compared to my ex-kwak it uses a lot, the kwak used nothing between oil changes. Dont treat a bike like a car, it will cost you lots. Dont know how long ago you did your bike test, but they may have told you how to check the oil, chain etc..., plus the service book says to check it every now and again.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#12 |
thanks for the replies.
ok...so it's looking like the engine had no oil... how come the LCD icon near the speedo wasn't on though? isn't that the oil level light (not the red one) cos that always goes off too once the bike starts if the bike went completely dry what's the likely damage and repairs gonna be then? |
#13 |
The Sick Man
anything could be stuffed, replace the engine is the only viable option
as long as there is a little bit of oil in the pump its enough to make the pressure on the switch, but still not enough oil to circulate the engine, once it came on it was gone there should have been signs like engine sounding noiser, engine temp higher than normal, revving diffrently. Unfortunate but you wont make the mistake again. SVs will run a fair while on low oil but when its gone it goodbye
#14 |
shouldnt the oil level light have come on though?
that's what i can't understand or is the LCD icon near the speedo not a level light...i know the red LED isnt a level light, but i thought the LCD icon of an oil can near the speedo was...isn't it? |
#15 |
There is no oil level light on an SV, just an oil pressure 'idiot' light.
I have no idea what you are talking about in the LCD pannel. ![]() .. other than that oil can .. lol, but i think that dissappears with the idiot light. Last edited by injury_ian; 09-10-08 at 11:48 PM. |
#16 | |
The Sick Man
On the Curvies there are two red lights, one on the tacho (water) and the other on the light cluster (oil pressure) If on most bikes, if the red lights are not on when you turn the bike on (engine not started) then its wise to consider a problem from the start.
#17 |
If you've run it low on oil then it's likely to have spun big end bearing on front cyl. Will have fcked the crank over properly and probably the rods too. Knackered.
P.s the red light doesn't come on untill the pump is sucking more air than oil, drops pressure low enough that damage is inevitable.
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 10-10-08 at 01:28 AM. |
#18 |
#19 |
#20 |
know anywhere where i could get an engine for decent money (besides ebay)
The Day The Music Died | Interceptor | Idle Banter | 2 | 07-02-09 02:24 AM |
It died. Part 2 | yorkie_chris | SV Talk, Tuning & Tweaking | 8 | 15-10-07 04:26 PM |
It died on me... | yorkie_chris | SV Talk, Tuning & Tweaking | 7 | 12-10-07 11:10 AM |
My friend just died | zunkus | Idle Banter | 56 | 27-02-07 02:05 PM |
HELP! My Bike Just Died On Me | g_conaty | SV Talk, Tuning & Tweaking | 3 | 11-11-05 01:09 AM |
