Old 13-10-08, 10:21 AM   #11
Default Re: Cutting Out 99 SV650s (Curvy)
Originally Posted by vardypeeps View Post
Yeah I was thinking that too. I will check out the wiring in the back of my tail pod and see if that sorts it. It's so strange as it does not seem to do it at a certain moment and I have checked all the loom before. I will take a second look see if there is anything I missed. Your problem sounds a bit like mine that I had with my head lights. One of the wires was earthing on the frame as the insulation had been rubbed through thus blowing fuses all the time. After I taped up the wire it was fine
Any way if you think you find your problem let me know as well and I will check on my bike
So Confusing
thanks for that. Before we swapped the engine, matt cleaned up connectors/contacts under the fairing, as I had a prob with the headlight flashing like Blackpool illuminations in sequence with the indicators, but it didn't blow fuses after he'd done that....it is an avenue to check amongst the main earth wire down the rear cylinder and the whole loom...sigh
SV650S K2 Last of the Curvy! GAZER For Sale - SV's and SV related items 3 07-06-08 08:18 PM
Curvy SV650S For Sale Marshall For Sale - SV's and SV related items 25 17-02-07 10:15 PM
Cutting point for Renegade standard level on a Curvy ['01] SV650S_DUB SV Talk, Tuning & Tweaking 2 29-03-06 06:34 PM
Cutting lowers on a Curvy? kinesin SV Talk, Tuning & Tweaking 3 08-02-06 12:18 AM
R&Gs For Curvy (K2 SV650S) - No Fairing Cutting Required exduker Ancillaries 0 22-08-05 09:51 AM
