Old 28-10-08, 12:55 AM   #11
Default Re: Bloody Focus broke again
Nah it could be far worse.
It could be.....
French.
Old 28-10-08, 03:55 AM   #12
jimmy-james
Fords are set to self distruct after 100k miles, always had a passionate hate for them as the Fiesta I used to have would cut out if you turned right, when it felt like it usually on the busyest roads or outside Mcdonalds when the chavs were about in the largest quantity. Strange that it didn't do it before going over the 100k miles mark..................Spooky.
Never solved the problem just sold it dirt cheap as a project and swore i would never have another Ford from that day forward.
Old 28-10-08, 04:08 AM   #13
BanannaMan
BanannaMan's Avatar
It could be.....
French.
This is true...
The few Renault's I've worked on have all been carp.
Seen a few Peuget's...not bad cars but a pain to work on.
(and worse to get parts for)
And of course you need those odd size spanners to even change the oil....
...Bill
Old 28-10-08, 07:44 AM   #14
muffles
i used to have an 03 focus - never had a problem apart from the aircon needed re-gassing. Is yours a pre-2003 model by any chance? Just wondering
Yep - a 98 - but 98-2004 is usually the same, what are you saying is different lol?
Originally Posted by BanannaMan View Post
Ahhh a bloody Ford....
Fix
Or
Repair
Daily
Agreed
I've got a strange cutting out problem actually, occasionally I will press the accelerator but nothing happens, and then it takes effect...not sure what's going on with it at the moment, I thought mechanical (sticking throttle cable?) but expected that to only affect it when lifting off (i.e. might stick on), so then I thought maybe it's not firing all the time for some reason (changed plugs recently) - but it would be everything not firing rather than only some cylinders. That's as far as my thoughts on it have gone
This is true...
I especially like Ford's use of a (rare) 7mm allen key on the front brake caliper sliders. Had to go buy one separately as none in any of my THREE sets. Why oh why?
Old 28-10-08, 08:14 AM   #15
Davido
Btw a tip for anyone else having window regulator trouble on focuses:
Remove the regulator, unplug it. Hit it with a hammer (I sh*t you not) and plug it back in. This fixes a fair amount of the ones that come into work.
Just something worth trying before shelling out for a new one. Although in the thread starter's case, it wouldn't really help.
Old 28-10-08, 08:43 AM   #16
Scoobs
That's what I did with the window regulator on my Golf. Works a treat.
Old 28-10-08, 09:35 AM   #17
454697819
Originally Posted by krhall View Post
You should worry I now have an alfa????
no your wife has the alfa remember....
Old 28-10-08, 09:39 AM   #18
454697819
My french car (when will I learn) is ok, few issues... (electric window broke and air con dont work)
awful to work on though... and made entirley of plastic
Old 28-10-08, 09:54 AM   #19
timwilky
timwilky's Avatar
My lads Kangoo is easy to work on being French.
Whoops forgot it is an Isuzu engine.
Not Grumpy, opinionated.
Old 28-10-08, 10:01 AM   #20
Scooby Drew
Fix
Or
Repair
Daily
First On Rubbish Dump...First On Rust & Deterioration...
Silverstone GP 30th July - Focus Events ?95 flibble Track Days 29 01-08-08 03:44 PM
Bikers beware of Ford Focus cars and don't ride out on Wednesdays Defender Bikes - Talk & Issues 21 05-09-07 08:14 PM
I battered a Focus Driver plowsie Bikes - Talk & Issues 13 22-05-07 12:50 PM
For Sale: ford focus 1.8 zetec kwak zzr Idle Banter 7 31-08-06 09:18 PM
YAY! I BROKE DOWN!! Last Action Pimp SV Talk, Tuning & Tweaking 36 28-03-06 08:35 PM
