Old 17-11-08, 11:11 AM   #11
600+
Default Re: Help with VOIP setup
what do you mean peering agreements TSM?
the previous O2 router had phone plugs built in and you could just enter the SIP details on there and it worked fine. unfortunately they don't give that router out anymore I had used voipbuster with that fine as well
Old 17-11-08, 11:22 AM   #12
TSM
The Sick Man
TSM's Avatar
Yep i had the same router as well, O2 are just BeThere rebranded as they bought them up a while back, annoying box as somtimes it would just drop its connection and you would have to then use the CP or restart the box. Now i just use an old Granstrom handset or a Sipura TA, my voipfone have autoconfig things to set my units up which is easy.
Peering agrements are links between VoIP providers, when you make calls between them, usualy they dont cost anything. At the moment the VoIP world does not have a unified cross link structure, but one day it may happen.
Old 17-11-08, 12:01 PM   #13
timwilky
timwilky's Avatar
Cannot help with your setup, but I use sipgate. you get your number on registration ( local numbers and not national).
Pros
Reliable
quick/easy to setup
reasonable peering
cons
charge by minute, you loose unused part of minute
only one number per account (but you can have multiple accounts).
However, my telephony costs are a fraction of what I used to pay BT & VM for. average monthly bill is now less than £5
Not Grumpy, opinionated.
Old 17-11-08, 12:10 PM   #14
SoulKiss
SoulKiss's Avatar
The 585 Routers SUCK big time
The one the BeThere supplied me only partially saved the config, and my Neighbour who also moved to Be, had even more problems
Go get a better router - it also means that they cannot then log onto your router and tweak it whenever they want.
Old 17-11-08, 02:32 PM   #15
there is also vonage, 5.99 month for free uk only landline. i have it and its great... but saying that i have cable and got rid of the cable phone so it paid for itself by doing that.
if you are a heavy landline user it may be worth thinking about... really easy to set up .. just plug it in and away you go.. you also get a free router/device. you also get a free geographical or local number.
i have had no problems what so ever in the whole time i have had it, which is about 3 years... its had call diversion to any number you choose in case your internet connection goes down ...
and here comes the sales pitch .. rofl.. if you do decide to go for it you can get 3 months free if you ask me..
http://www.vonage.co.uk/
sv setup, how much? Spike1105 SV Talk, Tuning & Tweaking 31 20-02-08 08:29 PM
VOIP hardware help required. Nekkid Idle Banter 3 16-07-07 08:26 PM
Sky Router & VOIP 600+ Idle Banter 8 01-05-07 06:32 PM
Front sag setup svrash Bikes - Talk & Issues 5 11-02-07 06:54 PM
Pointy K3> twin can setup for 650, does 1000 setup fit? aposegil Stuff Wanted 3 26-10-06 03:41 PM
