Old 23-11-08, 09:24 PM   #11
zadar
Default Re: GSXR fork and yoke dimensions
Originally Posted by Caddy2000 View Post
.... Of course I have been know to be wrong......
Old 23-11-08, 09:30 PM   #12
Caddy2000
If you're trying to tell me something then out with it man!!!
Old 23-11-08, 09:49 PM   #13
Should that 1mm make a difference? I would have thought that there would be enough play in the bottom yoke to take this into account.....
Don't do it.
Just get hold of the yokes from the same year or equivalent.
Old 23-11-08, 09:57 PM   #14
zadar
it will not work.
Old 24-11-08, 09:08 PM   #15
Caddy2000
just out of curiosity what are the dimensions of a pointy steering stem, diameter and length like
Old 24-11-08, 10:20 PM   #16
zadar
length is 258mm and bearing diameter 30mm.
Old 25-11-08, 10:24 AM   #17
Caddy2000
Zadar, you're a star!
Old 25-11-08, 03:25 PM   #18
Caddy2000
looking at new bearings (SV and GSXR 750 k7 use the same bearing), but was slightly put off by the cost. Saw these, and wondered if they would do the job. They're definately cheaper, OEM suzuki bearings are £35.70 (+VAT?).
Old 25-11-08, 04:16 PM   #19
http://shop.marksman-ind.com/steerin...003-1296-p.asp
Give them a ring and get hold of some koyo ones.
Old 14-12-08, 02:01 PM   #20
Caddy2000
I've moved onto the wheel now, and found that getting hold of the appropriate wheel is a bugger. The Delkevic wheel is actually cheaper to buy, but it apparantly only fits up to K4 machines.
I had a look on Alphasport's website and the part number for the bearings and spacers are the same for a K4 and K6 GSXR 600/750. So they will fit onto the spindle correctly (in principle), but what is the width of a K6/7 hub? Is it narrower that a K4 hub? Or is it because that the mounting holes for the 310mm disks are different than for 300mm disks...
Delkevic sent this info on hub dimensions:
"The width of the hub from sprocket do disk is 130mm, however the total width including the bearing housing is 150mm"
The distance between the forks (along the spindle) on the K6/7 is 154mm, and the thicker part of the spindle creates a 14mm spacer on one side.
Any ideas?
GSXR Front Wheel and Upper Yoke CheGuevara Stuff Wanted 0 15-05-09 09:27 PM
How to remove top yoke/fork bracket? sam anon SV Talk, Tuning & Tweaking 7 07-02-09 09:48 PM
GSXR 600 K1 Forks & Bottom Yoke for SV650 K3+ Conversion Ter For Sale - SV's and SV related items 9 21-04-08 08:00 PM
Gsxr 600 Top Yoke richwill68 Stuff Wanted 4 27-03-08 03:11 PM
SV GSXR Fork Swap - Keep Stock GSXR Damper? Mesomorphman SV Talk, Tuning & Tweaking 5 08-09-06 07:40 PM
