#11 |
do you literally just unscrew via the bot on the end of the rod and not the ball joint?
#12 |
Knob faced knobster
once you've got the footpeg asembly off you should be able to just unscrew the rod from the ball joint at the lever end
2011 Speed Triple 1050 |
#13 |
ahh yes got it off now cheers guys, any idea what i can put round the new bolt as i couldnt find the remains so the old peg??
#14 |
Knob faced knobster
You can run it with just the bolt but if you've got some o rings put them on it
#15 |
Don't muck about with crappy bolts and bodging o-rings on, do it properly with one of these. They hardly cost the earth and work very well. My SK5 has had one as a brake lever toe-peg for the past 11 months wioth no problems.
http://fixer-peg.co.uk/shop/category...ram=cid%3D3%26 From this ![]() To this ![]() I filed the scabby broken bit of the end of the lever smooth and fitted the new toepeg after painting the lever with silver Smoothrite... simple Last edited by Lozzo; 04-12-08 at 04:28 PM. |
#16 |
A bit of fuel pipe works well to slide over the end.
#17 |
so i would still need to drill through and put a bolt through for the replacement pegs Lozzo?? in that case its no harm drilling through and using a bolt untill it comes through the post!!
#18 |
Yes. Still need to drill through.
#19 |
its aluminium so its very easy and quick to drill.
#20 |
cheers, just ordered the replacement peg hopefully ill have it by the weekend and be able to get back out on the bike!!
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) | martin_SV | SV Talk, Tuning & Tweaking | 10 | 30-07-08 08:40 PM |
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. | Bayside GTR | Stuff Wanted | 0 | 29-10-07 11:24 PM |
2 left indicators + clutch lever + gear lever for pointy k6 | enduroman | Stuff Wanted | 3 | 06-09-07 09:26 PM |
A broken Gear change lever (Mk1SV) | Viney | Stuff Wanted | 2 | 19-07-07 02:04 PM |
Gear change lever | Ward8124 | Bikes - Talk & Issues | 0 | 03-02-07 04:19 PM |
