Old 24-12-08, 10:34 PM   #11
Stig
Default Re: oh my clutch
i've adjusted so there is no slack in the cable but no change
You have not adjusted the clutch. All you have done is take the slack out of the cable. Have you done a search for Sid Squids Clutch adjustment thread?
Old 24-12-08, 10:35 PM   #12
Wideboy
Evel Knievel
Wideboy's Avatar
i haven't taken the sprocket cover or anything off yet as i haven't had time
05 DRZ400E
RIP hovis
Old 24-12-08, 10:35 PM   #13
Wideboy
Evel Knievel
Wideboy's Avatar
yes i searched his threads and couldn't find it
05 DRZ400E
RIP hovis
Old 24-12-08, 10:37 PM   #14
Alpinestarhero
get the cover off and be armed with some wd40 to give it all a good clean first
Old 24-12-08, 10:45 PM   #15
Stig
Here you go.
Originally Posted by Sid Squid, Several Times Now
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod, back it out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
Old 24-12-08, 10:49 PM   #16
Wideboy
Evel Knievel
Wideboy's Avatar
cheers ape, i couldn't find it earlier
05 DRZ400E
RIP hovis
Old 24-12-08, 10:53 PM   #17
Stig
no problem. Do the adjustment correctly and then come back and tell us what its like.
Old 26-12-08, 12:36 PM   #18
Wideboy
Evel Knievel
Wideboy's Avatar
right so i've having a fiddle and here what i have, sorry if this is hard to understand but i dont know technical terms and not good at explaining things
right so basically i've done what sid said to do and nothign has changed, but what i have noticed is: when the arm is pushed down and the nut is tightened, when the clutch is pulled the push rod moves before the rest of it even though everything is tight, is it ment to be like that?, i hope you can follow
so i've taken the mechanism apart and taken the push rod out, this is where im going to loose you lol
you have the push rod arm bit which is connected to the bit that looks like a fat threaded bolt, now thats where i have free play, is it ment to do that?
05 DRZ400E
RIP hovis
Old 26-12-08, 01:10 PM   #19
chakraist
That's the worm gear- that can also be adjusted.
Old 26-12-08, 01:13 PM   #20
Wideboy
Evel Knievel
Wideboy's Avatar
Attachment 2908
this bit
basically i hold the bit where my thumb is and i can move the arm
05 DRZ400E
RIP hovis
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
clutch kit sv650nutter149 For Sale - SV's and SV related items 0 25-06-07 03:08 PM
clutch has had it! socommk23 SV Talk, Tuning & Tweaking 8 10-03-06 06:21 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
