Old 30-12-08, 05:04 PM   #11
m.dunthorne
Default Re: SV650S K2 Lower Fairing Bolt Kit
Dave
You mentioned about some brackets, are these needed? (if so where from) Also, any idea how easy/hard these are to fit?
You seam to be the SV god!!! I have looked at a load of different subjects and you advise everyone, Bow down to you Sir!!!
ps, do you know how to get pitted chrome front pipes back to their former glory???
Old 30-12-08, 05:12 PM   #12
Dangerous Dave
Originally Posted by m.dunthorne View Post
You mentioned about some brackets, are these needed? (if so where from) Also, any idea how easy/hard these are to fit??
Aye, they are necessary other wise the fairing would fall off (it what the bolt to). They are easy to fit, undo a bolt align the bracket up and replace the bolt clamping the bracket in place is usually the most difficult job.
Your expert there would be dizzyblonde, she is the org polisher!
http://forums.sv650.org/showthread.p...fork+polishing
What you need to do is remove the lacquer, it is that which is pitted not the metal. Best thing to do after polishing them up is to not re-lacquer them other wise you end up in the same place all over again in a years time.
Old 30-12-08, 05:19 PM   #13
m.dunthorne
Thanks again mate. I shall order the part tonight, says its complete with bolts nuts and brackets so whilst I'm waiting for that to arrive I think the front forks will come off and have some TLC. Thanks for all your help, I'll be in touch if there's anything else haha.
Mick
Old 30-12-08, 05:22 PM   #14
Dangerous Dave
No probs, anytime mate and fell free to PM if you wish.
Lower Fairing for curvey SV650S austin1 Stuff Wanted 4 17-04-09 10:39 PM
Lower Fairing Top bolt gromet and spacer DF! Stuff Wanted 2 20-09-08 05:06 PM
SV650S Lower Fairing sv650sfan Bodywork 5 07-01-08 09:16 AM
SV650S Lower Fairing sv650sfan Bodywork 0 12-12-07 02:31 AM
Lower fairing bolt djt_spurs Stuff Wanted 8 14-08-07 04:05 PM
