Old 11-02-09, 12:09 PM   #11
Default Re: Clutch problems (not the normal kind)
So, if you've altered the clutch cable over a million times, and it keeps changing itself on its own, and when in first gear it creeps, and then once warm its fine.....what would be the best thing to do, swap the cable first or have a peep at the worm?
Old 11-02-09, 12:14 PM   #12
Dave20046
Dave20046's Avatar
How bad does it get? There was a thread on someone where it started flapping about. Can't remember who it was though! possibly big ape?
Old 11-02-09, 12:17 PM   #13
Just wondering if its worth getting a new clutch cable before Tues when YC has a poke about. . . I'm feeling stingy and could rather do without
Old 11-02-09, 12:23 PM   #14
Dave20046
Dave20046's Avatar
I'd leave it, if it ain't a biggy. Spray grease or old engine oil down it and work the cable for a bit if you can be arsed.
Old 11-02-09, 05:36 PM   #15
Assuming the adjustment is correct, persistent clutch drag can be caused by a notched clutch basket, (or less commonly the same wear to the clutch hub), this causes the plates to 'hang' and not separate cleanly. If the damage is only slight, then it can be dressed out with a file, but only if it's really light.
Old 12-02-09, 09:04 AM   #16
vardypeeps
I will remember to check for notching of the clutch basket when I check the plates. I have a file lying around somewhere at home so will use that if there is only slight damage.
Is it a big job if the whole basket needs replacing? bikes only done 19000miles.
Clutch problems. otacon88 SV Talk, Tuning & Tweaking 13 16-05-09 06:19 AM
Clutch problems. chakraist SV Talk, Tuning & Tweaking 13 03-02-08 06:03 PM
Clutch problems from new dmracing SV Talk, Tuning & Tweaking 3 03-08-06 01:00 PM
Clutch problems? PWNDLOL SV Talk, Tuning & Tweaking 1 05-07-06 07:10 AM
clutch problems... SVNez SV Talk, Tuning & Tweaking 12 14-05-06 10:07 PM
