#11 |
Shirley you can strip the mech at the carbs out and ckean it out and grease it up? Where about in livi are you? I'm just along the road in sunny bathgate!
#12 |
its a friggin nitemare to get to tho! tbh all this dissassembly is freakin me out atm.ive never seen her in such a state! Im in North Craigshill and will be workin on it all day sunday,weather permitting
#13 |
don't forget copper slip to stop any future seizing. Start at one end and work back but i can't advise anymore as i'm a carb noob. Might be worth the R6 throttle mod?
#14 |
Do you have a haynes manual?
#15 |
nah not got one,its on my list tho
#16 |
on here somewhere there is a service manual. I've only got one for a pointy tho.q
#17 |
#18 |
im just gonna have to keep going and keep taking things apart,cleaning lubing and re attaching them.I should soon get to the answer.I was just worried that it was something serious that couldnt be remedied with wd40 and a tub o grease.Hopefully its not and ill be back on the road for monday.Thanks for everyones input
#19 |
Im confused as to what it coule be. I have never heard of a set of carbs siezing at all as most of the bushes in the pivots are brass! The only real way of sorting it is to take the carbs off and check, strip and clean. Its really not that hard, you will however, need a long philips screwdriver.
A couple of things to check. Take the airbox off so that you can get a better look at things. There is a linkage on the left of the carbs (as looking to the front of the bike) give that a tug. Make sure there is nothing fouling the mechanism at all. If you can, see if you can push the butterflys round with your finger. If noe of this is no, then it really is carbs off, strip clean and grease. USe white grease on the pivots. My bike is 8 years old and oterh than rusty cables, i have never had this issue. Good luck |
#20 |
This is a new one.
Try and wiggle the linkage on the left of the rear carb, see if the rear carb moves, there is a little bit of spring there. (careful with the adjuster screw, don't move it.) Then it's just carbs off, strip stuff down and grease it until it'll work.
Engine Seized | Stevetmanchester | SV Talk, Tuning & Tweaking | 14 | 13-05-09 12:08 PM |
How can I tell if my brakes are seized? | arcdef | Bikes - Talk & Issues | 16 | 17-11-08 02:31 PM |
seized bolt + more | hovis | Bikes - Talk & Issues | 26 | 07-01-08 11:06 PM |
Seized Clutch | squirrel_hunter | SV Talk, Tuning & Tweaking | 8 | 31-10-06 11:11 AM |
Think i've seized it :-( | Daimo | SV Talk, Tuning & Tweaking | 22 | 22-07-06 06:34 PM |
