Old 18-02-09, 09:21 PM   #11
jumjum_0214
Default Re: Oily right foot
The clutch covers warp, i put my money on it being from there.....
Old 18-02-09, 11:18 PM   #12
Yup, sounds like clutch cover.
That drain hose is either excess fuel or coolant.
Old 19-02-09, 07:49 AM   #13
branny
yeah, after a clean boot yesterday... 1 trip home and 1 trip back to work and there is fresh residue on the boot. (thats 16 miles in all, not really getting the engine warm)
To be honest, i am not THAT worried about it... it is more residue than fluid.
Unless i have a major reason to be worried?
My clutch is causing me unrelated worries... so if i require a new clutch or something, it can be sorted then. Speaking of clutches, what is the average clutch life?? I have people telling me that a motorcycle clutch never packs in, but i hear peopl on here having to replacing plates etc. I have done 25k.
Old 19-02-09, 01:17 PM   #14
Depends on use, some last ages, some people can destroy a clutch pack in a sunday afternoon.
Old 19-02-09, 01:22 PM   #15
branny
My clutch symptoms-
- first bites from cold start are very loud, kinda squeals.
- not the cleanest of gear changes... made bearable by a bite point at close to full lever extension.
I will see how it bears out into the summer. What is the most common failure case of a clutch? I don't see it being too high up the 'danger' list.
Old 19-02-09, 01:24 PM   #16
most common failure... bad adjustment!
Then worn lifter.
Notched baskets.
The plates seem to last a fair while.
Old 19-02-09, 01:26 PM   #17
branny
sorry... i meant, how does it fail when it goes? Just loss of gear changes?
I did the sid squid adjustment and i ended up with a bite point very far out from the bar, i think i will have another tinker and try to bring that in... but then gear changes seem a little more rough.
Old 19-02-09, 01:30 PM   #18
Other stuff ok? Oil level? chain tension?
Old 19-02-09, 01:33 PM   #19
branny
yeah, Oil is just changed and between the limits.
Chain on the other hand is at a tension making the best of the tight spot, it is probably too slack at its weakest. Also, when wheeling the bike, you do get a feint chain 'whirr'. Not sure how normal that is, but the chain has done about 8k, with scottoiler.
Cleaning Off Oily Muck chris8886 Bikes - Talk & Issues 28 01-01-08 08:55 PM
wanted - foot peg and foot brake lever bikerman Stuff Wanted 2 03-10-06 10:47 AM
Where is the foot? localhost Idle Banter 25 06-05-06 07:31 PM
Someone drove over my foot! northwind Idle Banter 28 01-05-06 05:22 PM
Trench-foot? Jabba Bikes - Talk & Issues 10 03-12-04 03:38 PM
